Old 06-01-2008, 05:29 PM
Promise4M Promise4M is offline
Short Ram Intake
I just installed a short ram intake into my car, and I am new at this. Is there anything else I must do for it to work properly after its bolted on?
Old 06-01-2008, 05:50 PM
Nforcer Nforcer is offline
You have been Nforced!
what brand did you use? model #? I've been looking for one.
92 Claret LSL #919
Old 06-01-2008, 06:04 PM
i actually bought this one. It might not be a huge company but it should still do the job
http://svx-motorsport-accessories.st...beshramin.html
Old 06-01-2008, 06:23 PM
redlightningsvx's Avatar
Collision Refinishing Tech
A hot air intake!!!! Run some piping into the fender well then put on your filter. Cold air intake is way better than sucking in hot engine air.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 06-01-2008, 06:26 PM
want to explain that a little more in depth. like i said I am new at this and i am not sure how i would do that.
Old 06-01-2008, 06:44 PM
crazyhorse's Avatar
242,000 mi on oem trans
When you pull your airbox, you'll find a hole in the fenderwell. You really should run pipe through that hole, then mount that filter to the pipe inside the fender. More accurately between the fender and the fenderwell.
What this does is allow your engine to suck in colder air, increasing HP. Mounting that filter to the Mass Air Flow (MAF) sensor, will net a lower restriction, making more HP. The cost is that the hot underhood air takes more HP than the filter makes.
"42"
Current Stable By Age:
Old 06-01-2008, 06:48 PM
thanks any other suggestions to increase my car's performance?
Old 06-01-2008, 07:43 PM
Wolfy's Avatar
Wolfy Wolfy is offline
Send a message via AIM to Wolfy
ram air not good?
so basically a ram air adds no hp? is it at least a little better than the stock box? cuz if thats true im just gonna put a k&n replacement filter in the stock air box...
Old 06-01-2008, 07:45 PM
What kind of piping would I need to relocate my filter? ((im not even sure if thats a good question))
Old 06-01-2008, 08:18 PM
You will need a piece of intake piping that has a 90 degree bend and cut to the size you want.
Seth
Past subies:
Other toys:
Old 06-01-2008, 09:39 PM
you DO realize of course that if you do this, you could possibly hydrolock your engine. rain + unrestricted air filter = dead motor! Personally, I'd rather suck in hot air.
92 Claret LSL #919
Old 06-02-2008, 01:34 AM
siceclipse's Avatar
siceclipse siceclipse is offline
the only chance you have of hydrolocking your motor is if you drive into a puddle the size and depth of a small pool
Mike
1992 SVX LS-L Pearl White 102,000 miles (Gone)
2005 Evolution 8 SSL Tarmac Black (new daily)
1995 Eclipse GSX Durango Copper Pearl (teh beast)
276awhp/280awtq @ 18psi (560's inj)
260awhp/260awtq @ 17psi (stock inj)
Old 06-02-2008, 12:40 PM
crazyhorse's Avatar
+1 on what siceclipse said.
If you mount the CAI just inside the fender opening & ensure that the inner plastic liner is intact, you'd have to go into water over your headlights to drown your engine.
Hydrolck=BAD JUJU
Check with TomsSVX about his Tomyx intake. Proven numbers, and you can get the CAI with it.
Thread here
"42"
Old 06-02-2008, 01:40 PM
dragoontwo dragoontwo is offline
he's not talking about actual ram air. a true ram air setup would net you more hp.
'92 SVX LS Pearl White - 6mt
Old 06-02-2008, 06:34 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Wolfy,
I tried the K&N filter and it screwed up my MAF sensor. It was probably the sticky spray you need to add to the filter. I believe others also experienced this.
