Old 05-24-2008, 08:27 AM
redlightningsvx's Avatar
Collision Refinishing Tech
Oil on ds brether hose/intake tube
Well another problem I notice was some oil on my driver's side breather hose on top of the valve covers. The passenger side has zero oil on it just that side and I noticed some oil residue in the intake tube before the tb. So any thoughts?
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 05-24-2008, 04:45 PM
bump............
Seth
Past subies:
Other toys:
Old 05-24-2008, 07:30 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
replace your PCV valve...
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 05-24-2008, 07:54 PM
It was changed about 5 months ago, I didn't think it would get clogged so soon but ohh well I'll get it changed at work. Thanks
Seth
Past subies:
Other toys:
Old 05-24-2008, 08:28 PM
SVXRide's Avatar
Make sure it was actually changed, as they are a total *#!~ to change out (it's on the underside of the intake manifold). You might want to check the line to the one valve cover to make sure it isn't clogged (not likely, but worth checking out). Easy way to check the entire system is to disconnect the line at the valve cover while the engine is running and see if you've got a "draw" on the line.
-Bill
