Old 05-20-2008, 06:32 PM
Manarius's Avatar
Manarius Manarius is offline
Originally Posted by mysvxrocks View Post
How do I cut the power to the fuel? I dont see a fuse for it
There should be a fuse for the fuel pump. If not you can unplug it at the pump.
The best way is this:
Either remove the fuel pump fuse or unplug the fuel pump at the pump.
Crank the car a few seconds. The car may start, but it'll die almost instantly.
The fuel lines will be depressurized at this point.
Doing it that way should minimize fuel leakage.
-Jason
-Obi Wan Kenobi
redlightningsvx's Avatar
Collision Refinishing Tech
Pull the plug on the left side under the rear bottom seat
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 05-20-2008, 08:10 PM
Speedklix's Avatar
Locker Link Solution
And for the last picture, can someone please tell me what those things are that are spliced into the fuel lines? I touched one and it shot gas all over.... Ive never seen those on another SVX before...
I want the name and address of the super guru you bought that car from PLEASE do not drive it until you fix that.
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 05-20-2008, 08:21 PM
mysvxrocks's Avatar
mysvxrocks mysvxrocks is offline
Im REALLY addicted! CANT STOP!
Send a message via MSN to mysvxrocks Send a message via Yahoo to mysvxrocks
Well some good news for everyone. I spent $20 and got all new hoses and clamps. Got them put in, so its as good as new!
Now onto the other issues in the main post
D.J. McPhee
2006 Infra-Red Ford Focus ZX3 ~ 67k
No longer SVX'n, Ill always miss them!
1995 Polo Green LS-i ~ 95k
1992 Dark Teal LS-L ~ 145k (04/91) #2231
Old 05-20-2008, 08:32 PM
Manarius's Avatar
If you have oil all over the engine crossmember, you need to replace the valve cover gaskets (those pictures are indicative of that). If you have spots around the back of the engine area, the rear main is leaking. If you have oil at the bottom of the middle timing cover, the front main gasket is shot as well.
My guess is that you need valve cover gaskets and a rear main gasket replaced.
-Jason
-Obi Wan Kenobi
