Alright, some pictures of my nasty engine...
Alright, so I had that thread about my engine leaking. Well its at the point where I need to order all of the parts I need to reseal. So can someone tell me, I think its obvious, but my valve covers need replaced correct? I can look at the how to for all of the gaskets I need for those, but could someone tell me what I would need to also do my front and rear main seals too? I dont know if they need done or not, but I figure if were doing this crap, might as well get it all. Also, while Im doing these things, are there any other gaskets I should replace? Im trying to get my engine to the point that I dont need to worry about it. Part numbers from subaruparts would be very helpful, as I want to be sure Im getting the correct items.
Thanks -Dennis Also, my timing belt cover is broken (the rear one) How hard is it to replace that piece? And does anyone have one they could sell to me? (The first pic shows where its broken) And for the last picture, can someone please tell me what those things are that are spliced into the fuel lines? I touched one and it shot gas all over.... Ive never seen those on another SVX before... <br> <br> <br>
D.J. McPhee 2006 Infra-Red Ford Focus ZX3 ~ 67k No longer SVX'n, Ill always miss them! 1995 Polo Green LS-i ~ 95k 1992 Dark Teal LS-L ~ 145k (04/91) #2231 1992 Claret LS-L ~196K (05/91) #0831 Last edited by mysvxrocks; 05-20-2008 at 05:10 PM. |
I swear those look like small motorcycle type fuel filters. Whoever put them in there was out to lunch, there aren't even clamps on the lines! Get rid of them, replace the lines with proper ones and fuel injected line clamps.
~ Chris
2020 Subaru Outback Touring - Wife's first Subaru 2005 Volvo V70R - 5-cylinder love! :Heart: ** SOLD **1998 Subaru Legacy 2.5GT Wagon - MOST RELIABLE car I've ever owned ** SOLD **2006Subaru WRXSTi (Former "Boxer4Racing.com / Continential Tire" STi) - Built EJ22t block / EJ207 JDM STi "big port heads" - 9,000rpm MONEY PIT!!! ** SOLD ** 1995 "Tree-Hugger Green" SVX L AWD(5 MT) --- "Gumby" 130K miles #399 in MY95, my original love... |
Yes, please before anything else at least get some clamps on those lines!!!!
Should I just get new lines and clamp them in? What kind of lines and clamps do I need? Then how do I disconnect them without shooting gas everywhere? And as for the line thats the furthest back, where does it go? I can see the front two are short, but the back one goes back by the strut tower somewhere...
D.J. McPhee 2006 Infra-Red Ford Focus ZX3 ~ 67k No longer SVX'n, Ill always miss them! 1995 Polo Green LS-i ~ 95k 1992 Dark Teal LS-L ~ 145k (04/91) #2231 1992 Claret LS-L ~196K (05/91) #0831 Last edited by mysvxrocks; 05-20-2008 at 05:38 PM. |
Front-Supply
Middle-Return Rear-Vent For the front two you need to use line rated for Fuel Injection, I think it is 5/16" but I'm not sure, just take a section of it to the parts store, they sell it by the foot. You also need to use hose clamps made for fuel injection hose, the two clamps on the stock fuel filter next to the coolant tank are proper FI clamps. If you want to minimize fuel spray, cut power to the fuel pump while the engine is running. The car will die off after a few seconds once the fuel pressure drops down. You will still get some fuel coming out when you disconnect the hoses so have a rag ready and wear some eye protection. If you want to be real safe have an extinguisher handy. It would be best to completely replace the lines, but please for now at least get some clamps on there.
I plan on changing them out right now. But as I said, I dont know where the back one goes. I didnt move things around to really look, but could someone give me a guess? As it also has one of these things spliced in... and again, no clamps.
D.J. McPhee 2006 Infra-Red Ford Focus ZX3 ~ 67k No longer SVX'n, Ill always miss them! 1995 Polo Green LS-i ~ 95k 1992 Dark Teal LS-L ~ 145k (04/91) #2231 1992 Claret LS-L ~196K (05/91) #0831 |
Wanna see bad let me jack my car up and take a few pics :O its the Exxon Valdez oil spill under there. Soon as I can afford an engine reseal you can bet I'll clean the mess up.
1994 SVX L - FWD Barcelona Red 190K miles ~ SOLD 1994 SVX LS - 5spd AWD Emerald Green 202k miles PWR Radiator, HID 5000k, New paint job with issues, 17" STI BBS wheels, converted to 5spd AWD from FWD. Purchased from SVXyGirl 2/20/09 -- Undergoing complete rebuild 1993 Justy 4wd 5door- Teal of sorts , beater. 2008 OBXT Newport Pearl 65k miles |
That back one is vapor return to the tank, I think it clamps before it goes through the firewall?? If not see if the have a hose barb to splice the line, or if there is enough line there to reach without that filter and the extra piece.
I do not want to see what it looks like under mine....
I would really like to just pull the engine out, and REALLY clean it up, as well as under it. That would also make replacing things quite a bit easier. I can see by just looking there, it is really bad. I hate driving it, because as soon as I come to a stop, smoke starts pouring out of every crack in the front.
That vapor line does not need a clamp like the other two fuel lines, that type won't hurt, but the factory clamp for the vapor line is just a spring clamp.
I go through a quart a month o and can't park in driveways without leaving my territory marks. I still love my car!
DANG that hose is expensive! They want 4.35 a foot!!!
Yeah, but I don't think the vapor hose will be that much.
How do I cut the power to the fuel? I dont see a fuse for it
Thread Tools | |
Display Modes | |
