Old 05-19-2008, 10:22 AM
Cynic's Avatar
Cynic Cynic is offline
Question Static from speakers when off
When I turn off the stereo, the speakers are still picking up sounds...i.e. if I hit the illumination button on the end of the signal arm, I hear a loud crackle. And different actions will make the static-y sound from speakers.
Doesn't happen all the time.
Any ideas? I'm checking fuses today.
Cyn
92 Ebony Pearl LS-L 199,000K New Tranny (my DD)
89 Chevy Sprint (for when my baby's in the shop)
05 Mazda 3 (Hubby's DD)
"You win some, you lose some, you wreak some." Dale Earnhardt
Old 05-19-2008, 01:55 PM
ShiuludeSVX's Avatar
If you've done anything with the speakers, or the stereo lately, then I would check for a wire with a bare end, or an open in the wire that is contacting something metal along the way. Most likely where you were working. Maybe even the back of the Head Unit touching a bare spot on a wire.
Can be a troublesome trace, but worth it, if it's persistant.
The Worm
_______________
June '91 Claret LSL #1733, Enkei RS-5's x 16", Original Paint, accompanied by Beautifully speckeled Front Bumper, Sony Audio Components, Small Car Shift Kit, "How to" Hood Lifts {Perfect}, "15 Minute Suspension Mod"
Motorsport Floor Mats. Perma-Cool External T. Filter, New Front Axels {1/2008}. "Classic Radiators" unit "$36 coil alternative" and Tranny rebuild at 287k 8/2012
'05 Infinity G35 Coupe.
No Mods, 33K Miles
Old 05-19-2008, 02:18 PM
Ownbot's Avatar
Ownbot Ownbot is offline
I'm the anti-do-gooder
alternator whine. I take it you have a amp? The noise is getting in through your pre-amps I suppose.
Old 05-19-2008, 08:52 PM
Cynic's Avatar
Thanks for the ideas.
Stock stereo as far as I know, and the previous owners didn't seem the type to change it. I'll check the speakers and look for an amp...under the seat, I suppose.
Its weird, only does it some of the time, and different things set it off...sometimes just closing the stereo door.
Rained most of the day, so didn't get to fuses. Tomorrow during my split shift.
Cyn
Old 05-19-2008, 11:17 PM
kwren's Avatar
kwren kwren is offline
couldn't be...
a fuse....
Old 05-19-2008, 11:25 PM
Jtuck Jtuck is offline
You might need to check the wiring harness behind the radio, it could be that your speaker wires are touching another wire or metal thats causing it to make noises.
Old 05-20-2008, 10:11 AM
crazyhorse's Avatar
242,000 mi on oem trans
I was going to say, it sounds like one of your speaker wires has grounded itself.
Listen carefully, see if you can isolate which speaker is making the noise. Then you can run that particular wire down, looking for bare spots.
Here's a GREAT chart with wire colors for the stereo.
http://www.geocities.com/svxdc/Audio...adioConnPinout
"42"
Current Stable By Age:
