Old 05-13-2008, 08:57 AM
Wikedjuggalo's Avatar
Rebuilding
O2 Sensor Stupid Question
O.k I had my car all jacked up and was ready to remove the O2 Sensor well, I can't get the damn thing off. I can't get the 22mm wrench around it! Someone help me or give me some advice :/
Old 05-13-2008, 09:28 AM
shotking's Avatar
shotking shotking is offline
Are you being held up because of the wire? If so pick up a tool like thesehttp://www.napaonline.com/MasterPage...cket&VehCode=N
Joshua
92 Ls-L pearlie 73,000 miles
Old 05-13-2008, 09:36 AM
Both Autozone and Advance Auto have O2 Sensor Wrench kits in their loan a tool program.
If you can get the wrench on but can't turn it loose, run the car to heat up the pipe, then try it. If you don't enjoy burnt fingers, you may want to break them both loose a few turns, then let it cool before you completely take them out.
Old 05-13-2008, 09:45 AM
kwren's Avatar
kwren kwren is offline
there is a..............
push on connector up above the 02 sensor.
Just disconnect it and slide the box end wrench right over the wire
Keith
Old 05-13-2008, 11:57 AM
Rebuilding
Thanks all I will stop by and see about the loan a tool. I couldnt get a wrench around it but When i get home I will thanks a ton!
Old 05-14-2008, 08:10 AM
Rebuilding
Well I got it done I went to a trusted mechanic and using his driveway and his jack propped the car up. Was a bit hard to get off but some stuff he had to "unlock" the threads did the trick kinda like wd 40 but I can't remember the name. All is done. Just was weird the code flashed a few times never stayed on. Lets hope that helps my 14 mpg -.-;;;
Old 05-14-2008, 08:40 AM
shotking's Avatar
PB Blaster?
Joshua
Old 05-14-2008, 09:22 AM
Rebuilding
Not Sure :/ I'm going out ther tomorrow I'll get the name
Old 05-15-2008, 07:38 AM
lechnoid's Avatar
lechnoid lechnoid is offline
Tech & Almost Lawyer
Originally Posted by shotking View Post
PB Blaster?
I PB
PB > rust
Old 05-18-2008, 09:30 AM
CorSVXette's Avatar
Classic SVX
Which one of those sockets is for the SVX?
Paul
1969 Corvette
1995 Corolla
2003 Highlander
Old 05-18-2008, 10:18 AM
Rebuilding
I did the "free" loaner tool from Autozone and it was the 22MM work Also had 7/8 or what ever on it. I had to put 32 dollars down for their set and got it back once I was done. Made it very easy and quick. Just let your car cool if run before you attempt this stuff is hot down there.
This is they one I used
Old 05-18-2008, 12:20 PM
kwren's Avatar
A box end wrench works great...
