Old 04-30-2008, 04:43 AM
mhl0125 mhl0125 is offline
Send a message via AIM to mhl0125 Send a message via Yahoo to mhl0125
Weird Tranny Problems.
When my car is cold, the tranny shifts through all gears just fine at all speeds. One it is warmed up (after driving 5-10 minutes), the engine just races in all gears and the front part of the tranny starts smoking. If you shut it off and let it cool down, it will once again shift through all gears only to start revving again (in any gear) after 5 or so minutes of driving. Do I need a total rebuild? No tranny codes.
Michael
1994 Barcelona Red SVX-LSI
Two-owner:169K
1995 Emerald Green SVX L AWD
#80 - Custom intake w/cone filter
99K with killer stereo system
2002 Acura MDX-Touring Edition w/navigation
2008 Toyota Prius
1987 Mercedes Benz 560SL
Old 04-30-2008, 07:10 PM
Michael when you lose all drive, do you lose 1st and reverse selected with the shifter?
If you do, it is most probably a lack of line pressure, that could be caused by:
1. A blocked oil pick-up screen in the pan.
2. A loss of pressure at the pump, due to a leak at the pump gasket.
The "smoke from the front part of the tranny". I
can't see this as being coming from the transmission itself, it is most likely to be coming from a leak at the cooler pipes that run from the front of the case. You have checked the ATF level in the box, I guess?
Old 05-01-2008, 07:36 AM
It revs in all gears including 1st and reverse. The tranny fluid level shows full.
Michael
Two-owner:169K
2008 Toyota Prius
Old 05-01-2008, 08:20 AM
paulmeisterpk's Avatar
paulmeisterpk paulmeisterpk is offline
Sconnie
Send a message via MSN to paulmeisterpk
That is exactly what my trans did. Tore it out, found the clutches all burned up, and rebuilt it. Sounds to me like you need a trans rebuild if your fluid level is correct as you said.
