Old 04-17-2008, 01:31 PM
mysvxrocks's Avatar
mysvxrocks mysvxrocks is offline
Im REALLY addicted! CANT STOP!
Send a message via MSN to mysvxrocks Send a message via Yahoo to mysvxrocks
ABS Light came on....
Why is my car doing this to me already
The abs light came on last night, and has been on since. Then today, I noticed it was rather hard to push the brake pedal down, so I gave it a good push, and it gave in, but it almost hit the floor. It did that to me twice, then went back to normal. Can someone tell me what my car is doing??
Thanks -Dennis
D.J. McPhee
2006 Infra-Red Ford Focus ZX3 ~ 67k
No longer SVX'n, Ill always miss them!
1995 Polo Green LS-i ~ 95k
1992 Dark Teal LS-L ~ 145k (04/91) #2231
Old 04-17-2008, 01:51 PM
GreenMarine's Avatar
From POST-***** to LURKER
Thanks -Dennis
Bled your brakes reciently?? Possibly the ABS unit is dying... I know jack about the ABS units though, only standard hydraulic systems...
I know I need to bleed my system...
Oh, forgot to mention... I went over a bump last week and my ABS light came on too... If anything the braking felt better to me when the light was on (Stiffer pedal)... Then after stopping the car and turning it off, it hasn't come back on since then... Hmmm, oh well... No biggie I guess
~ Chris
Old 04-17-2008, 03:09 PM
This can happen when the ABS relay fouls up... Try unplugging the pump connectors (two on the pass side fender) and see if it does it still
Old 04-17-2008, 05:46 PM
mysvxrocks's Avatar
Alright I will try that. If it doesnt work... What do you think the problem is? How much does a new ABS unit cost if thats it... likely quite expensive...
D.J. McPhee
Old 04-17-2008, 05:51 PM
new pump or control module?? Pumps RARELY go bad. If the control module is shot, it just defaults to non-ABS braking. IF the pump relays are whacky, they will kick the pump on at random times and screw stuff up like you are describing... its the relay under the black box on the pump w/ the ABS letters on the cover
Old 04-17-2008, 06:56 PM
mysvxrocks's Avatar
So I just take the black box off that says ABS on the main unit, and theres a relay there? How much would it cost to replace the relay? And where could I get said relay?
D.J. McPhee
Old 04-17-2008, 07:16 PM
Yeah, unscrew the cover, there is a relay under there. Take it out, I usually use one from a spare pump I have laying around, never bought one new.. I am sure you could get one from a parts store if you brought it in... First thing is to unplug the pump to make sure it stops the funky brakes
Old 04-17-2008, 07:19 PM
mysvxrocks's Avatar
Would I unplug both of the connectors? How long do I leave them like that?
D.J. McPhee
Old 04-17-2008, 07:53 PM
Yes, leave them unplugged until you are satisfied knowing that it didn't act up again
Old 04-18-2008, 12:19 PM
mysvxrocks's Avatar
So theres 2 relays in the ABS unit... Which one do I take out? Or should I replace both of them? I unhooked the unit, and the brake issues I were having have went away, so its obviously something with the unit.
D.J. McPhee
Old 04-18-2008, 12:42 PM
nextse7en's Avatar
Graphic Artist
When you replaced the shoes, were you gentle with the lines? If you have air in the system, it will go almost to the floor like that.
I would venture to guess that since this happend after you replaced your pads, it has something to do with that. As tom said, the ABS module rarely fails.
I wouldn't say that because you pulled the relays, the unit is bad, if anything, that means that the relay is sticking, or worn. You may want to ask earl if he can loan you 2 known good relays, and see if the problem goes away.
-Patrick
Patrick
6Xk Miles.
[SIGPIC][/SIGPIC]
Old 04-18-2008, 12:45 PM
mysvxrocks's Avatar
Well I didnt think the unit is bad, just the relays. I went to autozone, and they didnt have either of them. Would NAPA have replacement relays? Or is this going to be something only Subaru carries?
D.J. McPhee
