Old 04-13-2008, 03:02 PM
SVX92-97's Avatar
SVX92-97 SVX92-97 is offline
Arrow Radiator ATF fitting
Does anyone know where I can get the ATF fitting that screws on to the bottom of the radiator. The nut that screws on cracked in half when I was gently checking the tightness. It must have already had a stress fracture I guess. Im in the process of replacing the atf in and out hoses and clamps. Evidentally legacy radiators are different. Im not looking to buy a whole new radiator just to replace one fitting as the subaru dealer wanted me to. I havent checked local junk yards yet, but will do so tomorrow. I thought you could buy these in your local auto parts store, guess not.
1995 POLO LSI 76K MILES SOLD
Old 04-13-2008, 03:35 PM
If it holds coolant with out that fitting, I'd just switch to an after market ATF cooler and bypass the stock one...
Old 04-13-2008, 03:41 PM
kwren's Avatar
kwren kwren is offline
Might have a problem with the bypass....
Not sure but I believe the transmission needs a certain minimal temp for operating that it gets as it goes through the radiator?
Keith
Old 04-13-2008, 04:13 PM
Mine is completely bypassed. In the winter I use a piece of plastic to block airflow over the cooler and it maintains the temp between 130-150*
Old 04-13-2008, 04:46 PM
ideal running temp is held by the Radiator... If adding a cooler it should pass through the external cooler first then to the radiator, then back to the transmission. This will allow the fluid to remain at operating temperature but not get too hot. Dave's suggestion will also work if the rad is having issues holding the ATF, in this case it is so an aftermarket cooler will be a suitable replacement.
Old 04-13-2008, 06:01 PM
SVX92-97's Avatar
Arrow
Im NOT installing a cooler at this time. I just need that fitting in order to connect the atf hose so I can drive the car.
Old 04-13-2008, 06:18 PM
The SVX is more than likely a one of a kind thing, so finding a used one will prob have to come from an SVX... Best thing to do is pull the fitting and go to some local hardware and autopart stores to find a match
Old 04-14-2008, 11:55 AM
SVX92-97's Avatar
Thanks Tom, Ive figured thats what Im up against.
