Old 04-03-2008, 12:16 PM
Rhoujin's Avatar
Rhoujin Rhoujin is offline
Send a message via AIM to Rhoujin
Two different rack and pinion assemblies?
deleted due to my stupidity -_-
1995, L AWD, Laguna Blue
Old 04-03-2008, 12:50 PM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
There are 3 different steering racks.
1) The standard rack. Fitted to the USDM base model and JDM S3 model.
2) The speed-sensitive rack. This is the most common one. Fitted to almost all JDM, Euro and higher-spec USDM models.
3) The 4WS front rack. Fitted to the JDM VL model. Rare outside of Japan.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 04-03-2008, 01:23 PM
Rhoujin's Avatar
Could you tell me the physical differences between the first two?
Old 04-03-2008, 02:35 PM
b3lha's Avatar
Phil & Belha
Type 2 has an electrically operated solenoid valve. It's a cylinder, with an electrical connection, next to where the steering column attaches.
Type 1 does not have this. The gear ratio inside is also different.
