Old 03-26-2008, 06:44 AM
pearlm30's Avatar
pearlm30 pearlm30 is offline
How do I quiet a noisy front differential???
Just got a 98 subaru forester with very noisy differential. Found out it was ATF in the differential. Put in the correct 80W90 gear oil lube in and its still very noisy.
What can I do to quiet it down? The car drives nice and I dont want to replace the whole transmission if its not broken.
Any suggestions?
Thanks in advance
94 Bordeaux Pearl SVX Lsi B&M cooler with Aux ATF filter. QC Kit Plus 06 Sti Gold Wheels. SOLD
92 Claret WRX 5 speed ECUTune 1AV1 Gold STI Wheels & more. SOLD
92 Teal SVX LSL lowered with Konig. SOLD
92 Black SVX LSL with B&M cooler & Aux filter. Small Car Shift Kit. Gone
94 Red SVX L FWDwith LSL Leather Interior. SOLD
92 Teal SVX LSL....with B&M cooler & Aux filter. Small Car Shift Kit. SOLD
95 Polo Green........With Trany Problem. GONE
Almost complete Rear Wheel Bearings Job with Pictures in my locker
My Locker http://www.subaru-svx.net/photos/user.php?pearlm30
Old 03-26-2008, 07:25 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Noise tends to be precursor to failure, sorry.
-Bill
p.s. keep an eye on the fluid in the diff to see if ATF doesn't show back up. If it does, you've got a trans-diff seal issue.
Retired NASA Rocket Scientist
Center Network Member #989
Old 03-26-2008, 07:43 AM
You may well have, probably do have, a damaged bearing that is making the noise.
This will just get worse and worse until it breaks, or until it is so noisy you have to get it replaced.
Making it quiet is only a short term solution, you really need to get it fixed.
Having said that you may be able to keep it from getting worse for a short while by adding a modifier to the oil. One I could suggest is Molyslip ATFA. It should not hurt to try a tube of this stuff. If it does not work, then plan on replacing the bearing.
http://www.molyslip.com/Products/MolySlipATFA.html
CAUTION: Do not use Molyslip friction modifier for manual gearboxes in your differential. This will cause the LSD to stop working because of no friction. Only use the one mentioned above.
Also please note you act on the above advice at your own risk. The correct thing to do is replace the noisy bearing. Best of luck with it.
Old 03-26-2008, 03:40 PM
I'd bet someone did a flush and added ATF instead of the proper oil, probably at one of those speedy-lube type places where there's one person under the car and one over. I've been asked what Subies take in the front diffs and get funny looks when I don't say ATF.
