Old 06-03-2002, 11:45 AM
TapperManor
Am I getting screwed!?
Hi All,
I brought my car to a suby dealer (Subara of Claremont, NH) to get my flywheel and/or flexplate replaced. (previous post) and a transmission fluid flush.
This is what they are charging me:
diagnose $69 (I told them it was the flywheel when i got there)
flexplate $45
labor $261
trans flush $120
Then in the process of doing the above work, they recommended more work, which I agreed to:
water pump, $386 parts and labor, (I know it was leaking)
timing belt, $290 parts and labor (hasn't been done since 60,000)
I got them to go down $50 doing the above 2 things together.
Then the tech says there is no rear transmission mount, and it hasn't been there for a long time.
parts $126
labor $58
That seems a bit rediculous for a mount, don't you think?
Does the above pricing seem reasonable?
The good new is the master tech says that my transmission is in good shape. (A different suby dealer said otherwise)
Ken
http://macsdeli.com
Old 06-03-2002, 12:13 PM
wasions's Avatar
wasions wasions is offline
SVX Black Belt Master
Yes.
We all are (well, maybe with the exception of Beav).
(Oh man. I think I just stepped in something. Right, Beav?)
Steve
'95 Polo Green SVX L AWD, 188K - "Kermit" (Gone, but not forgotten)
'02 Outback LLBean, 56K
'02 Black Sapphire Volvo V40, 133K - "Shadowfax"
'06 Triumph Tiger, 19K
'99 Suzuki DR350SE, 8.5K - "Geezer Killer"
Old 06-03-2002, 12:23 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
The water pump labor includes replacing the timing belt. The t-belt itself lists at around $100. Don't let them charge you for something you're already paying for.
As that was a professional response I'll be billing you for $129.
I'll be billing Mr. W the standard fee if $1298.47 - you don't want me to bill you for the explanantion also, do you?
Old 06-03-2002, 12:44 PM
TapperManor
Thanks Beav,
I just called them to clarify and they agreed there would be no labor charge for the timing belt!!!
Ken
Old 06-03-2002, 04:20 PM
Beav's Avatar
Not as old as Randy
A friendly gesture would be to take a bit of those savings and donate them to the network here.
You're welcome, we're all here to help each other.
Old 06-03-2002, 05:03 PM
svx_commuter's Avatar
Do you have to take out the tranny to put in the flex plate? Cause the tranny mount comes out to take out the tranny. So I think the labor on the mount is high. NO MOUNT? or a broken mount?
Old 06-03-2002, 05:36 PM
Beav's Avatar
Not as old as Randy
That's true John, I missed that. Other than what, two bolts and the mount would be changed. Sic 'em Tapper, grrrrrr!!
Old 06-03-2002, 06:13 PM
TapperManor
Good idea, I been meaning to do that anyway.
I was reading Aredubjays' lonnngggg post about the Network earlier.
Old 06-03-2002, 06:20 PM
TapperManor
They said there was NO mount in the rear and that it had not been there for some time. I found this a bit peculiar since this is a one owner car and has been dealer serviced its whole life. When they (suby) replaced the tranny at 70,000 maybe they forgot it????????!
You think the labor is high, I would probably agree.........but...I think $126 for a bracket a couple of bolts is rediculous!!
Old 06-03-2002, 08:24 PM
Invisible avatar
Re: Am I getting screwed!?
[QUOTE]Originally posted by TapperManor
[B]Hi All,
flexplate $45
labor $261
trans flush $120
What kind of tranny flush? I got a T-Tech (supposedly safer than other types) last week for $89.00 including the fluid (organic). I WAS charged an extra 20 bucks for labor to replace the external filter that I supplied.
Ron.
'96 Grand Caravan - 240K
'01 Miata SE - 79K
Old 06-03-2002, 08:30 PM
TapperManor
Re: Re: Am I getting screwed!?
[QUOTE]Originally posted by Ron Mummert
[B]
Hi All,
flexplate $45
labor $261
trans flush $120
Ron.
They said they would take every drop of fluid out (they acted like this was a big deal?) including droping the pan and cleaning the mesh filters. I'm not sure if I have any external filters. Are they stock?
Old 06-03-2002, 09:34 PM
Invisible avatar
Re: Re: Re: Am I getting screwed!?
The '92 ('93?) had an external filter - look under the battery holder. I believe this filter was added as a factory recall. Those with more info please chime in.
Ron.
'01 Miata SE - 79K
Old 06-04-2002, 09:28 AM
shoden's Avatar
shoden shoden is offline
I'd be happy to be paying what you're paying... it's a heck of a lot less than what I'm getting hit for... see my post about the $1150 water pump for details....
Old 06-04-2002, 10:21 AM
That would leave a lot of weight and loads on the motor mounts. I think the tranny would have been banging around on the rear cross member when you went over bumps. May have had an effect on the PROPELLER shaft center bearing also.
Old 06-04-2002, 04:37 PM
Beav's Avatar
Not as old as Randy
I agree, there's something awfully stinky here and it ain't fish.
