Old 03-10-2008, 12:02 AM
rear camber bolt size?
are the front camber bolts the same size as the rear? i don't think so, but i'm hoping they are cause i can get an extra front set easy. if not, what size do we need?
Old 03-10-2008, 07:54 AM
'E''s Avatar
'E' 'E' is offline
yes they are, i looked into this as i need to adjust the rear camber for my new rims
92 pearl SVX about to revive
92 Black 4ws (Jap spec) SVX
93 black SVX
93 Liquid Silver SVX - sti 6 speed with R180 diff, my05 sti steering wheel, sti alloy lateral links, 19x8.5 275/30 42mm offset front and 19x8.5 275/30 22mm offset on the rear, 6 pot brembo caliper with 355 rotors front, 2 pot brembos rear
95 bright red SVX
96 emerald pearl SVX about to revive
Old 03-10-2008, 08:06 PM
excellent thank you! will get my hands on these this week end and report back.
Old 03-18-2008, 01:45 PM
update, the OEM front camber bolts will not fit the rears, they are too large. i've grooved/notched out the oem rear bolts and will try to get a little camber adjustment that way. will tell you if they work later when i get a chance to put them on and measure them up.
