Hella Supertones!
I just bought a set and I'm trying to figure out where to mount them. The traditional behind the grille location the Impreza guys use doesn't work on the SVX (too tight). I searched and found someone had installed a set, but I don't know how long it's been since they were online. Sooo, has anyone installed a set, and if so, where did you put the horns?
I can't wait to get these running. 118 dB ought to be plenty to get people's attention.
I think this is what SVXcess has?? I know he installed an aftermarket horn.
Yes I did install the Supertones. I took out the old horns to make room and mounted one horn on each side of the engine bay.
Photos in my new locker HERE .
Ah, awesome. What is the pass side on attached to though?
It is an aluminum L-shaped bracket, with one hole to mount the horn and the hole at the other
end using an existing bolt. Once they are tightened down, the aluminum is flexible enough to allow for some minor bending to allow them not to touch anything and vibrate. I also used a 30A relay and a 20A inline fuse to allow for maximum current flow and circuit protection .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 03-04-2008 at 08:40 PM. |
Great, thanks. I've already got all the wiring, connectors, etc to make it work. The stock horns in my SVX are absolutely pathetic, whether by design or age. This should make a nice change.
Another reason to come to Reading: see the Supertone install in person!
Like I need another reason! Getting a whole ton of new parts, rust-free doors, and spending a weekend with you lot is good enough for me! Besides, mine will be installed long before Reading (like tomorrow)
Supertones
I thought you were referring to the band that I haven't heard of for over a decade. Woops.
On topic, my horns suck too. What made you chose the Hella kit and what does it cost?
"They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." Benjamin Franklin blk 92' LSL w/ average mods pics here http://s306.photobucket.com/albums/nn277/yourconfused/ Cash68: "Hmm, I wouldn't brag about beating Escorts. That's like saying you tricked a retarded person." |
You can get the Hella Supertones for $57.00/pair plus shipping from Amazon com HERE
The quality of these horns is first-rate, Solid metal construction and very durable. Low profile to fit in tight spaces. These horns are made in Germany and of high quality. I have used these horns on other cars and was always pleased (and sometimes svxcess is very hard to please) Here are wiring diagrams I created to show the circuitry. One unexpected added benefit is the additional relay in the circuit softens the "chirp" of the arming and disarming of the alarm system. Some of the energy used to chirp the horns briefly is absorbed by the activation of the added relay. But when the horn is activated normally, or through the setting off of the alarm... WATCH OUT!!! .
Posting my post here so I can find this thread easily in case I lose it in the future. Considering this upgrade to my wimpy XT6 horn. Thanks for the post.
Kevin Thomas 1997 2.2ltr Subaru Impreza Outback Sport Wagon (AWD/Auto) 13.03@100mph 1989 2.7ltr Subaru XT6 (AWD/Auto) 15.912@85.93mph 1996 3.3ltr SVX (AWD/Auto) 15.070@91.38mph ***R.I.P*** 2010 RAV4 AWD Sport (13.717 @ 99.19mph ) 2015 Honda Fit LX CVT (15.2 @ 90mph) |
how difficult is this on a scale of 1 - 10, 10 being the most difficult...I would like to do this, but am not all too familiar with wiring schematics and rigging something like this up...
If 1 is changing a wiper blade and 10 is rebuilding an automatic transmission, I'd give this a 2 or 3. Most people are just afraid of working with wires, once you give it a shot it isn't hard at all. Crimp-on quick connectors make life easy.
are there instructions included?
There's some pretty terrible instructions included, but there's a very good how-to on NASIOC. I'll see if I can find it again.
Edit: Got it: http://forums.nasioc.com/forums/show...lla+supertones
