Old 02-10-2008, 05:51 AM
tubbstcg tubbstcg is offline
engine strength
Ok well i was j/w what are the weak links in the svx engine? Im thinking about making my own turbo set up and im wondering how much boost i can shoot for without running up the bill too terribly high....any thoughts or suggestions are appreciated?
Old 02-10-2008, 09:48 AM
intercooled with good EM you can run about 10 psi without too much worrying too much.. weak points are listed in order
1. piston ring lands
2. Rod bolts
3. rods
4. Head bolts
Thats about it... the engine is of a great design minus the scissor cam gear design which is foolish for making power.
Old 02-10-2008, 10:04 AM
dragoontwo dragoontwo is offline
Why is that, Tom? I've never seen a cam gear set up like this, but I'd like to understand why.
Mike
'92 SVX LS Pearl White - 6mt
Old 02-10-2008, 10:21 AM
my goal is to try to get about 300 or a little more reliable horsepower.
Old 02-10-2008, 11:06 AM
Mike
Because there is no way to adjust the cams without using 7* increments and even then its foolish as you have to pull the cams, which sucks when they are in the car. Its just not user friendly
Old 02-10-2008, 02:36 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
YT,
you forgot main bearings (?)...or should it just be the clearance that the factory would like them set up to?
-Bill
p.s. how about head gaskets?
Retired NASA Rocket Scientist
Center Network Member #989
Old 02-10-2008, 04:05 PM
well im wondering if you guys have any ideas to acheive that kinda horsepower and the problems i face ...i wanna go the turbo route but its not set in stone
Old 02-10-2008, 05:03 PM
well you can do three things.
1. Nitrous -cheapest and easiest
2. StageIII supercharger
3. Custom FI system
My stage III is for sale right now, and as far as I know, the only one available anywhere
Old 02-10-2008, 05:04 PM
Originally Posted by SVXRide View Post
YT,
-Bill
What'd ya lose my number??
The main bearings are really not bad, the few times they have gone is because of clearances being too tight. Headgaskets are just failing because of age and use... not really HP... Don't forget I use stock HG's in my engine builds
Old 02-10-2008, 07:43 PM
SVXRide's Avatar
nag, nag, nag
yeah, it would be running to the small end of the FSM's clearance spec.
yeah, tell me about HGs going
-Bill
Old 02-11-2008, 05:50 PM
now ive also considered a twin turbo set up but it sounds to me like a whole hairy ordeal if i were to try a small turbo and a big turbo would i need custom ecu tuning
Old 02-11-2008, 05:57 PM
you are going to need tuning regardless. To imagine that one chips works for all SVXi with different kinds of FI is silly
Old 02-11-2008, 06:01 PM
ecutune offers a Maf sensor and fuel system that can handle 500hp am i gravely mistaken in thinking it would work for most aplications if you had manual boost blow off valves....im new to all of this and if im wrong feel free to send me in the right direction im just trying to learn
Old 02-11-2008, 06:06 PM
understood, but the ECUtune software might allow you to run a turbo or supercharger but it is by no means tuning. All that software is made doing road tests and has customer dyno charts. No dyno tuning which is where tuning needs to be done to get the most out of it. MUCH better off with a standalone and having it tuned by a professional. Those are my plans once I can sell my supercharger kit
Old 02-11-2008, 06:16 PM
how much would professional tunning run? ...if i had a unlimited budget i would send it off and let people that know a lot more about what they are doing than me but being a sixteen year old born to a middle class family no such luck in sight so im trying to meet my goal as cheaply as possible without compromising too much
