Old 02-09-2008, 01:19 AM
emmasweeny emmasweeny is offline
Dead in driveway
Several problems, but lets start with the immediate one. Right now if I let my 1992 SVX sit for a few hours disconnected from the battery it will start and run for 4-5 seconds before shutting down. Checked the codes and it's throwing a 12. I'm suspecting the MAF but the starter switch may be bad too as it's pulling amps while turned off. I'm way open for suggestions.
Roy
Old 02-09-2008, 06:53 AM
Does it run rough while it is running?? I gotta look to see what a code 12 is
Old 02-09-2008, 09:54 AM
re: DiD
It revs up smooth, then it's like the computer shuts off spark. And 4-5 seconds may be optimistic.
Old 02-09-2008, 11:10 AM
well that makes sense. The code is for the ignition switch... Time to break out the multimeter or maybe just a test light to find out where you are losing continuity.
