Old 01-29-2008, 07:51 PM
ok, http://www.rathracing.com/store/inde...category_ID=13 like i said, it's for a quad which are obviously way lighter than our cars, but it should mean one for ours isn't out of the realm of possibility.
Old 01-29-2008, 08:21 PM
-JJ-'s Avatar
-JJ- -JJ- is offline
Endangered Species
Send a message via MSN to -JJ-
STI use CF for their strut brace: http://www.mastrowrx.com/index.asp?P...MMP=1013122570
not quite the same load but still used from tortional strength
1992 Pearl / Black SVX
removed intake silencer, k&N pannel filter, trans cooler, 94 JDM 4eat, Noltec front swaybar mounts, Motorsport D&S disks with EBC Greenstuff pads
Old 01-29-2008, 08:40 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
As I mentioned earlier, the only way a CF sway would make sense would be if you had a three piece set up - which is exactly what you've uncovered Note that the "arms" are chrome moly and the CF main bar has metal splines on the ends. Yes, there is no reason why the same kind of set up wouldn't work on a car. Yes, it would probably cost an arm and a leg due to the fabrication of the CF bar and the integration of the splined ends with the CF such that you won't get delamination under load.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
