Old 01-21-2008, 07:59 PM
Nevin's Avatar
Nevin Nevin is offline
power steering whine
Well, the last few weeks have been pretty cold here in Iowa, and like most cars, mine does not like it at all. I always let it warm up at least 5 minutes before I go anywhere so that helps, but my power steering has been whining at me pretty good recently.
On average, it's been between 5 below and 0 degrees every morning for the past week and I always wince (sp) when I start the car because I know the P/S is not going to be happy. I had just been putting it down in the "cold weather" column, but could it be something else? I check it every other day or so, and it's never been low yet. Also, I added some Nichels power steering conditioner about 3 weeks or so ago. It actually kinda seems to do it worse since then, now that I think about it.
Anyways, do you think my pumps going bad, or should I just wait it out until the weather warms up? If it does go bad, it's not a HUGE deal to me...just replace the pump, and BAM. So yeah, just curious if others have had this problem, or possible solutions.
Thank you.
-nevin
Jesus is the remedy
2015 Expedition EL Ecoboost
Old 01-21-2008, 08:10 PM
I have 'morning sickness' on my truck too. I can't turn the wheel at times which is rather scary. This started after I replaced the pump about 6 years ago. I know it is a faulty pump, but I have learned to deal w/ it. Just rock the steering wheel side to side a few times and I get a little movement, then full movement and I can steer again. Stupid GM.
As for your car, search, find o-ring results, do the how-to, drive a fixed car.
It seems the o-ring is usually the issue on the svx.
blk 92' LSL w/ average mods
Old 01-21-2008, 08:14 PM
Nevin's Avatar
O-ring, huh? Interesting. If anyone else knows anything about said o-ring, I'd sure appreciate hearing it!
*searching now*
Jesus is the remedy
Old 01-21-2008, 08:28 PM
Nevin's Avatar
Ok, did a bit of searching and found THIS page. Only problem is that the computer I'm on won't open whatever file this is that shows me what to do.
Don't suppose I could trouble someone to give me a run-down and just explain how to do it... if that's possible??
Jesus is the remedy
Old 01-21-2008, 08:34 PM
*searching now*
Start your search up in the "How to documents"
Old 01-22-2008, 12:40 AM
Check out the How-To Docs. It is in a PDF format.
Old 01-22-2008, 09:27 PM
Crazypolo95 Crazypolo95 is offline
95pologreen
Send a message via AIM to Crazypolo95
yeah me too i found out that sometimes you just need to add power streeing fluid
