Old 01-20-2008, 06:01 PM
Jason Olson Jason Olson is offline
clear memory mode
Ive followed the manuals specs to clear memory. but when i go to read memory same codes flash. what am i doing wrong? Also if a sensor is diconected while car is off will it trigger a fault?
Old 01-20-2008, 06:05 PM
What year is your car? Disconnect the battery overnight and when you re-connect it the codes should be cleared.
Old 01-20-2008, 06:09 PM
Its a 95 and thanks much am happy to hear its simple!!!
Old 01-20-2008, 06:24 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Make sure you correct the problem or the codes will come back again.
