Old 01-14-2008, 10:23 PM
Lockleaf Lockleaf is offline
Pretend Innovator
Wiper Arm doesn't move
My passenger side wiper arm doesn't move when I turn on the wipers. I figure it has to be one of two things. wiper arm bushing, or else the connection between the two wiper arms is disconnected. However, can anyone think of anything else it might be? I've only had the car a few days and this was the first time I had tried using the front wipers. Thanks guys
Old 01-15-2008, 09:53 AM
dcarrb dcarrb is offline
I would check to be sure the nut securing the arm to the drive post is good and tight.
dcb
Old 01-15-2008, 05:07 PM
Yes, the rubber cap on the arm can hid that the nut is loose and that will cause the arm not to move.
Old 01-15-2008, 05:11 PM
94SubieSVX's Avatar
OOC for a while
Even if the nut were loose, the arm should still move with the motor right? Because isn't there grooves to catch it on the motor stub, and on the inside of the arm?
bLAh
Old 01-15-2008, 05:16 PM
It may be stripped out then.
Old 01-15-2008, 06:10 PM
Seraphinwolf's Avatar
Seraphinwolf Seraphinwolf is offline
H6 THE ONLY WAY!
Send a message via AIM to Seraphinwolf Send a message via Yahoo to Seraphinwolf
What about a rear wiper? Any ideas on that? I can hear the signal trigger something. I'm hoping it's not one of those things that they won't let my car pass inspection for caues it's stuck half way and won't move by hand.
-Gaddis
94 Bordeux Pearl LSi (Jun 2009) 109k Plate:GADDIS
What they call it a vanity-plate. Shouldn't I be obligated to be vane with it?
Rota Tarmac 3's 18x8" on 245/40/18 Dunlop SP Sport 600's, Perrin light weight crank pulley, PRW radiator, custom coilovers(not GC's), 9006 HID 4300k 50W low beams, DIY garage door lip, and SVXfiles brake kit. Fixxed exhaust so no more sweet sound.
97 White/Black trim Impreza Outback Sport (March 13/08) 150K-180K(sensor broken)Good news is EZ30R and 05' 6speed full powertrain swap is in motion!: Will be doing more work as I can. Gonna be run by a Hydra so yeah fun to be had.
[SIGPIC][/SIGPIC]
-Gaddis
Old 01-15-2008, 06:50 PM
-Gaddis
If you're worried about it passing inspection, just unbolt it and rebolt it in the parked position. They'll never give it a second thought...
Old 01-15-2008, 07:13 PM
H6 THE ONLY WAY!
Ummm... yeah I was more wondering on actually fxxing it. I've stuck my head up in there as best I can but since my trunkhead liner doesn't want to come out I can't really get at it. Like I said there's something triggering like an actuator or something. Guess I'll just do that for inspection though.
-Gaddis
[SIGPIC][/SIGPIC]
-Gaddis
Old 01-15-2008, 07:17 PM
You're going to have to get the trunk lining down to check it out.
Let me know if you need a rear wiper motor...
Old 01-17-2008, 03:05 PM
On my old 1985 Subi I had the nut get loose. I was told by the dealer it was designed that way incase the wiper froze to the window the nut would loosen like a clutch. I lifted the cap and tightened the nut.
