Old 01-13-2008, 08:54 PM
Psychosis5150's Avatar
Psychosis5150 Psychosis5150 is offline
Yugo aficionado
Water in trunk, after sealing taillights...
The trunk seal seems good, and I already pulled the tail lights out and sealed them... Now I'm confuzzeled. Any other known leaky areas in our trunks? Rear wiper maybe?
92 Teal 181K
4:11 trans
Lightweight crank pulley
Redline Shockproof
Trans Cooler
Viper 550 HF Alarm/Remote Start
18" Enkei Evo5's
Old 01-14-2008, 09:26 AM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
Might want to check the rear sunroof drain hoses to make sure they are not loose or broken. They run down inside the side panels. Sometime back a forum member mentioned a leak around the antenna.
Gene
Gene and Ben
Old 01-14-2008, 01:17 PM
94SubieSVX's Avatar
OOC for a while
Gene
When mine weren't plugged in, they drained into a little "reservoir" type thing off to the left side of the trunk.
It's hard to get to if you still have to trunk panels in, as you have to reach down pretty far.
bLAh
Old 01-14-2008, 06:21 PM
Yugo aficionado
Thanks guys, I'll take a look next time I'm home from work before dark
92 Teal 181K
4:11 trans
Redline Shockproof
Trans Cooler
18" Enkei Evo5's
