Old 01-14-2008, 06:09 AM
CorSVXette's Avatar
Classic SVX
Originally Posted by SURTEESS View Post
The mirrors on my Dec 95 are non-motorised, but they do fold - both forwards & backwards.......(one of them has loose mirror glass, is there anyway of tightening this up?)
thanks
Steve
Auckland, New Zealand
Fowards and Backwards? I didn't know that
Paul
1969 Corvette
1995 Corolla
2003 Highlander
Old 01-14-2008, 08:38 AM
thanks
Steve
Anybody reading this who may have motorised closure [i.e. you own a JDM car] do not try folding your mirror forwards, you will break the mechanism!!
If the mirrors do not have closure motors, then they will fold forwards or back OK.
Steve, describe how the mirror glass is "loose". The glass panel is stuck on to a flat plastic plate. This plate pivots vertically or horizontally so that the mirror can be set for driver position.
Is your glass loose from the plastic plate, or is the plastic plate flapping about?
Old 01-14-2008, 10:13 AM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Cool loose glass
Well - I bought the car second hand 12 years ago (does that make me the longest surviving SVX owner?) it had only 15k on the clock - the car is a red Dec 95 with now only 115km done & yes no the number plate is not for sale.
The glass shakes (maybe 2-3mm when pushed at top/bottom/side to side) - I suspect that it is on a ball socket & there is some sort of clamping arrangement arround the ball that was loose at the time that I bought the car - it is quite annoying at night as the lights of following cars seem to flicker & catch your eye - the other mirror is tight on the pivot point.
I have full set of manuals & have not seen any postings as to what the mechanism is (or for that matter how to get the mirror off) - I presume you need to remove the door lining etc ....
Any help would be great as this is the only thing I have had to do to the car in all the years that I have owned it (apart form adding a towing hitch, & the JDM had a rear window shelf de-ioniser/blower for the rear passengers to get some fresh air).
Pictures are on the following pages - all taken in Auckland, New Zealand.
http://www.subarusvx.com/images/carpics/red/red074.jpg
http://www.subarusvx.com/images/carpics/red/red075.jpg
http://www.subarusvx.com/images/carpics/red/red076.jpg
http://www.subarusvx.com/images/carpics/red/red077.jpg
thanks for any help (or photos / links on the subject)
Steve
Old 01-14-2008, 12:52 PM
Steve
Oh, so your car is 1 of 1! I have seen the tow hitch picture before, nice car you have.
Steve, you did not answer my query as to whether the mirror glass is loose from the plastic backing card [you could check this by noting if the plastic lip remains all around the mirror glass as you move the glass the 2-3mm you mention]
I suspect the glass is secure to the plastic, and the whole assembly is loose and wobbly. There may be an easy cure for this. Attend carefully.
You will be aware the mirror moves smoothly in the left-right or up-down axes when you use the electric controller. You may not be aware that the mirror pivot can be moved manually through a very broad range independent of the motor. This is so that you can arrange the mirror in the best position relative to your seating position. You are correct about the ball & socket arrangement, but each mirror pivot will move for physical pushing through a number of "steps". These steps seem to be about 5 degrees apart, and when you have selected a step or spot, this then becomes the central position around which the motor moves the glass plane, right-left, up-down.
If the one "step" you are using has come loose, there is the possibility if you can move it to a nearby position, the new position might be tighter. If all the positions on that mirror are shaky, then you will have no option but to take off the mirror by taking off the screws at the back, like you suggest.
Here is how you should check it out; first, before you try the shaky mirror, try out the steps on the good passenger side. Grip the mirror housing firmly, with a thumb on the glass on each side. Press firmly one side, letting the other thumb up, of course, until you hear the dull inner click as it moves position. The first time you try this you will probably push it three or four clicks or more, so go easy.
Now that you know how much pressure to apply to achieve a click, try the same on your loose mirror. If you manage to click it into a nearby tight position, you problem is solved, just readjust with your electric switch. If it won't click, or if all positions are loose, then you must take off the housing and tighten the ball joint.
Old 01-14-2008, 02:21 PM
SURTEESS's Avatar
Cool loose mirror answer
Sorry - the mirror is not loose from the backing plastic, so will check what you suggest tonight, will let you know tomorrow.
thanks again.
Old 01-14-2008, 02:45 PM
Best of luck with it then. Let us know what you find out.
Old 01-14-2008, 03:08 PM
That is a very nice looking car. The only other thing I might mention is that your wheels are on backwards, but maybe not, you are in the southern hemisphere.
Old 01-14-2008, 04:30 PM
redlightningsvx's Avatar
Collision Refinishing Tech
I WANT you center tail light bar
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 01-14-2008, 04:51 PM
SURTEESS's Avatar
Cool
Sorry the light is not up for grabs - but there is a guy here in Auckland who is wrecking a couple of JDM SVXs - got the rear (big) light from him after I stuck a bike pedle through the original light + the rear tray de-ioniser / blower
- the NZ version & USA versions of light are different eg
NZ
red reflector // white rev // SVX name // white rev // red reflector
USA
red stop light // white rev // SVX name // white rev // red stop light
the NZ (and maybe Australia?) had no stop light in the cluster only a reflector, but the wiring was in place for the "upmarket version. Similar issues for the front headlights, NZ (non JDM) models had the fog lights blanked off (but in this case no wiring, and other lights used different shape connectors for the other lights).
I can give you guys contact details for the guy wrecking the 2 SVXs if you want - I thought about getting the leather seat cover from USA SVX as your passenger side is mostly new (due to fact that you guys drive from other side of car).
Old 01-14-2008, 06:12 PM
i just want it because its the same as our us tail light bars but yours is in black letters and ours isn't
Seth
Past subies:
Other toys:
Old 01-14-2008, 06:26 PM
SURTEESS's Avatar
black letters ???
but I got mine from a wrecker in the USA ... you mean there are other differences in the lights???
Old 01-14-2008, 06:27 PM
SURTEESS's Avatar
wheels on backwards...
Yes they got fixed "very" soon after the pictures were posted a few years ago..
Old 01-14-2008, 06:47 PM
in your 4th pic it looks like black letters and the white lights are in different positions then ours
Seth
Past subies:
Other toys:
Old 01-15-2008, 10:15 AM
SURTEESS's Avatar
Cool rear light options & "wobbly" mirror
see my post approx 5 above to see the 2 versions of light set-ups that I know of.
As for the mirror issue, it is loose no matter what position I set the glass at.
So this means taking off the door interior stuff to get to mirror - will post a few pictures during the process (also of the mirror mounting mechanism).
thanks guys for all the help & suggestions
Steve
Old 01-15-2008, 11:00 AM
SURTEESS's Avatar
Cool ALXFORYOU - what about a photo or two
Since in the original thread you mentioned buying a broken SVX mirror, why not show us (me in particular) what the insides are like with a couple of photos
Also if some one has photos of the motorised folding version that also might be useful for someone else?
thanks
