Old 01-09-2008, 06:42 AM
nsm484's Avatar
nsm484 nsm484 is offline
Teh Geek
Send a message via ICQ to nsm484 Send a message via AIM to nsm484 Send a message via Yahoo to nsm484
Exclamation Tranny help :-/
Ok, First off, No codes, I am not getting any errors of any kind.
I make a turn, any turn, and give it too much gas, and my rpm's jump though
the roof as if I am in netural.
Also, maintaining a slower speed, sometimes I will feel, and hear a jolt...
closest thing I can relate, is take a Manual, maintain a speed, and pop the clutch, while not releasing the gas, the rpms dont jump, but you get that thud from under you that makes you scared that your tranny is about to die.
I am very confused with the problems, I've been having to pull out into traffic at angles, or accel straight then turning as I let off the gas.
someone please give me some idea's.. I've had someone at work tell me it mite be a Center Diff problem, but I'd rather hear from the people here first.
-Roger H. | Website - nsm484.com | Facebook - Roger Harvey | Twitter - nsm484 | Personal Locker
2002 Mitsubishi Lancer OZ Rally [Nori]
1996 LSi Polo Green [Calista] - 18" Konig Incident's - Lived for awhile Now Selling
1992 LSL Dark Teal [Yori] (Rear Ended, Donor to Calista, and now gone)
1992 LSL Ebony Mica (Sold to svxcuseme)
Old 01-09-2008, 08:22 AM
Have you checked the transmission fluid when the car is running and sitting on the level in park?
Drain the transmission pan, remove the trans pan and change the internal filter.
Is the trans pan dented?
Is the screen in the trans filter clogged?
Was there an O-ring where the filter goes up into the transmission?
Do these things first.
Old 01-09-2008, 02:14 PM
If your description can be summarised as:-
When turning and only when turning, power transmission is disengaged.
When in a straight line there is sometimes a thud which appears to be a short similar disengagement.
---------- The front differential is the prime suspect item.
Old 01-10-2008, 11:10 PM
nsm484's Avatar
Teh Geek
thats pretty much it, there was once where I was going in a straight line, hit the gas pretty hard so the %@#hole behind me wouldn't rear end me, where it disengaged for a good 1/2 a sec, and BANG, (I drove 35 the rest of the day that day, it was a huge thud :\ )
Old 01-10-2008, 11:12 PM
nsm484's Avatar
Teh Geek
Haven't check fluid level yet, can do that sat.
Filter, where can I grab one? Hopefully the tipical places (Advance Auto?)
