Old 05-07-2002, 08:27 PM
SVX10's Avatar
SVX10 SVX10 is offline
Fighting with electricity
For those with good ears
Hey. Well, I've been complaining about a buzzing in my exhaust. It's not the resonator (I have the KC exhaust system), and it's definately coming from the catalytic converter area. It's not the heat shield on the main cat because I've had that off for about 5 months now. So, I have a sound clip of the buzz. If somebody could tell me if this sounds like a bad cat, I'd like that. For a little background, the buzz doesn't seem too be around when the car is revved up in neutral or park. When put under a load, it buzzes. Especially noticeable when starting from a stop on an uphill slope, or when the car shifts into second gear quickly, and accelerates from very low RPM in second. Thanks in advance.
Mat
P.S. The rattle is most obvious (to me anyway) the last 2 times I rev the engine. Unfortunately, the laptop gets lots of the engine noise to confuse everything.
Old 05-07-2002, 11:32 PM
DavieGravy DavieGravy is offline
Re: For those with good ears
Unfortunately I can't be of direct help, but after having my resonator chopped of at meineke muffler, and having it replaced with a piece of straight pipe, I still have a rather loud buzzing noise untill the car warms up. Not as bad with the resonator though. I was told that something inside one of the catalytic converters can actually make the preceeding resonator, or whatever after market parts you've put on, cause a buzzing noise.
Dave.
Out for good.
Old 05-08-2002, 05:54 AM
Mr. Pockets's Avatar
Moderator
Mat
I don't know what a bad cat sounds like, but to me it sounds more like a hole in your exhaust. A small one, but that's what I hear.
If I were to expand on it, I would say that the hole is probably after the pipes merge. If it was only one side of the exhaust you would hear more of a put-put noise.
Hey, good job recording this. It sounds pretty good. Not studio-quality, but pretty damned good. How'd you go about it, exactly? If more people recorded their noises (and compressed them to MP3 format - WAV is kinda big), we would have a better consensus on what noises were what.
Hell, we could even have a database of noises and their causes.
Good idea, me.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 05-08-2002, 09:29 AM
wawazat??'s Avatar
Yeah, I'm still around
Re: Re: For those with good ears
Good idea, me.
Nick,
I'll bring my portable mini-disc recorder and mic to the 10th Anniversary meet and we can go out scouting noises to record for your project.
Todd
Down to none
Old 05-08-2002, 11:28 AM
SVX10's Avatar
Good Idea
I like the sound database Idea. That'd be a great help sometimes, i'm sure. To record mine, I did one with my laptop sitting under the car about 1' and the one I posted, I had my laptop sitting in my lap and a plugged in microphone sitting about 5" away from the cat. Real easy. If anybody wants any recordings of anything, lemme know and I'll do it. I don't know how to compress to MP3 form, though.
Old 05-08-2002, 01:27 PM
Moderator
Re: Good Idea
Mat, you need a program called dBpowerAMP Music Converter. It's real slick and will convert WAVs into MP3s. It also rips and converts an entire CD in about ten minutes. I will, however, be happy to convert this one and include it as the first in my 'collection' of SVX sounds. Once we get an actual diagnosis on your noise, I'll include it as the symptom.
I actually didn't even realize that you started the thread. The sound I think is an exhaust leak is probably your aftermarket exhaust.
Listening to the file again, I now hear the rattle. Jeez, it could be anything. Try getting under the car and tapping on things with a screwdriver or (small) wrench until you find the same noise. It's not a high-tech solution, but one that's worked for me before.
2005 Outback
END OF LINE
Old 05-08-2002, 04:00 PM
SVX10's Avatar
been there
done that...I already tried poking around. Can't seem to find anything. Like I already said, I'm leaning toward exhaust system because it's worse when the car is under load. It's probably a leak, so I think I'm gonna take it to a muffler shop Friday and see if they can find any leaks. I honestly think it's a Cat, though. Or maybe I'm just hoping it's a cat so I can get a new one and "regain some lost power" .
Old 05-08-2002, 04:15 PM
svxeno
I go along with the small hole.
Randy (Listening to the buzzing in my head) ii
Old 05-08-2002, 07:48 PM
Invisible avatar
Wink
[QUOTE]Originally posted by svxeno
[B]I go along with the small hole.
It's taking every fiber of strength within my warped mind NOT to respond to this one.
Phew!!! Ron.
'96 Grand Caravan - 240K
'01 Miata SE - 79K
Old 05-09-2002, 06:55 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Talking I hear ya Ron, I hear ya!
I can't tell much from the recording (sorry) but I can tell you that a bad cat' sounds like a rattle, like a golf ball in a small coffee can. The tin around the outside of a cat' can buzz, however. Leaks can sound like many things because of their size, distance from the engine, yadda, yadda, yadda.
