Old 08-26-2007, 11:06 AM
Scott's Avatar
Scott Scott is offline
Send a message via AIM to Scott
Car randomly decided it wouldnt start. Help?
Hey all, I drove my SVX home from work the other day. It started up with no problems like always, and drove home without ANY incident. Then an hour later, I got back into the car to drive to Orlando and, all of a sudden, it refused to start.
The engine will crank all day long, which leads me to believe it's not the battery. My first guess is that it's either getting no fuel or no spark. I haven't checked anything yet due to my incredibly hectic schedule. But it definitely seems weird that it would die completely and without warning. I remember my first car had a little sensor that would detect some sort of impact, and basically immobilize the car. This could also be wired into the alarm system. Basically, all it did was kill the power to the fuel pump, and you could reset it by pushing a button located in the trunk. Is this by any chance a feature of the SVX? Anything else I can try before I start pulling fuel and electrical lines?
1988 BMW 325i Coupe - Bronzitbeig - Track Car Project
2003 VW Passat Turbo - Indigo Blue - Daily Driver
Sold: 1992 Subaru SVX LS-L - Pearl White/Black
Old 08-27-2007, 06:24 AM
dcarrb dcarrb is offline
Did you try holding the gas pedal to the floor as you cranked the engine? Don't pump it, just hold to the floor and release immediately if it fires.
I'm not aware of any sort of reset button for the security system.
dcb
Old 08-30-2007, 09:33 PM
Scott's Avatar
dcb
Tried holding the gas pedal. No luck.
Tried resetting the ECU. No luck.
I guess I'll have to start tracing through the fuel delivery system first and foremost to see if there's a clogged line or a bad pump.
Any other ideas?
Old 08-30-2007, 10:24 PM
Timing Belt??
Old 08-30-2007, 11:43 PM
subarufamily subarufamily is offline
possible MAF issues when my Mass air flow meter went it did the same thing would crank crank crank no start checked CEL found it out maybe could check for stored codes
Old 08-31-2007, 07:44 AM
lhopp77's Avatar
lhopp77 lhopp77 is offline
Old Timer (age that is)
Belt
I would also check the timing belt first.
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
92 SVX LS Pearl (Parts)
01 F150 4X4 Red
FREEDOM IS NOT FREE
Old 08-31-2007, 10:59 AM
AFBeefcake's Avatar
Subaru Swapper
Temp sensor. My car did that a couple times, but holding the pedal to the floor it would start. Temp sensor fixed it.
2005 Legacy GT
My WRX's Cardomain Page
Old 08-31-2007, 12:17 PM
vrkSVX vrkSVX is offline
1992 Pearlie original owner
Love your line from "The Princess Bride"
'92 Pearlie-bought new
'10 Forester - burgandy
Old 08-31-2007, 02:30 PM
timing belt is a good idea to check also
Old 08-31-2007, 05:03 PM
cozykat's Avatar
cozykat cozykat is offline
Still rebuilding my block...
Alcyone Silver Contributor
Any other ideas?
Have you tried spraying Carberator or Throttle Body cleaner into your intake on the Throttle body? As I understand if you spray it alot with the cleaner and your car starts, that will confirm it's got something to do with the fuel lines/pump.
Other reasons I've heard suggested for a car not starting: dirty/failed MAF, temp sensor, throttle position sensor, speed sensor, oxygen sensors, knock sensors, bad coil packs (especially if you recently replaced your spark plugs)...
Are you getting an codes from your ECU?
Marisa
Old 09-04-2007, 07:57 PM
Scott's Avatar
Thanks for all the input. Will be trying it all out this week and will report back when I find the culprit.
