Old 08-23-2007, 01:16 PM
processengr's Avatar
Code 23-abnormal MAF voltage
Hi,
I keep getting code 23, MAF voltage abnormal on my daughters 92. Car was stalling and idling poorly after major service (timing belt, cam seals, vc gaskets, sparkplugs, crank seal, etc.) Then after about 600 miles, it healed itself! I pulled the code, then tried to reset with the two blue wires in the 1st two left positions of connector. But code comes back immediately. I hate to fix what is not broken, car is running excellent...any ideas?
Cheers! Gordon
1992 Ebony 251k 444 SOLD
1999 Silver SLK230 134k SOLD
1997 Green Outback 137k SOLD
2013 Honda Accord I4 SOLD
2015 Subaru Crosstrek 30k
2018 Tesla M3 30k
Old 08-23-2007, 01:40 PM
AlcyoneDaze's Avatar
<-- custom hood ornament
I have a brand new OEM MAF sensor installed and am still throwing a code 23, even after 40+ driving cycles and a few attempts at code clearing.
JDM 4.11 Geared Transmission
JDM 'ALCYONE' Rear Panel
JDM 'BOXER' Eingngine Cover
JDM 'SVX' Hood Badge
L-Edition Suede Rear Seats
Old 08-24-2007, 05:37 AM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
I think to completely clear the code in your case you have to disconnect the battery and let it sit overnight. Maybe someone could clarify this better.
1995 Subaru Svx L / AWD
Old 08-24-2007, 08:29 AM
JaySVX's Avatar
JaySVX JaySVX is offline
Not quite over-night, 30min or so is more than enough.
The MAF connector, make sure that all the leads on the end are clean and clear of obstructions/corrosion. Make sure it's making a good connection with the MAF. Bad voltage could be additional impedence caused by crud of some sort on the connection.
Mine went bad yesterday, i replaced it on my lunch break, and now it's running perfectly, hopefully you'll have as good of luck as i did.
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
Old 08-25-2007, 11:36 AM
Thanks!
I left the battery disconnected overnight. It worked!! Even better, after driving an hour, still no codes
Many thanxs!
Cheers! Gordon
2018 Tesla M3 30k
Old 08-25-2007, 11:22 PM
longassname's Avatar
Just some dude.
ya, good stuff
You just had a code stuck in memory. Trust me if you had a bad maf meter you would know. Try unplugging it sometime and see how your car runs...it's not pretty. If you do do that then you'll get the code again, lol.
