Old 08-21-2007, 09:11 PM
SVXgarcia SVXgarcia is offline
Send a message via AIM to SVXgarcia
starting issue
Anyone know of a good toyota corolla forum?
If not please help.
car:toyota corolla 1995
car used to start fine, then it would take a couple of turns before it finally started (no clicking, no starter hesitation), finally today it just didn't start. the problem usually started during colder days.
Old 08-21-2007, 09:36 PM
Speedklix's Avatar
Locker Link Solution
probably the fuel pump.
any other symptoms?
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 08-21-2007, 10:25 PM
no other symptoms. I was thinking maybe an ignition module?
anyway to narrow the problem down?
Old 08-21-2007, 10:40 PM
Speedklix's Avatar
OHH, by turns did you mean of the key? or of the engine?
-Mike
[SIGPIC][/SIGPIC]
Old 08-21-2007, 11:10 PM
yeah, key turns. when the problem started it would take a few key turns before it finally started but no clicking or starter hesitation in between the key turns
Old 08-21-2007, 11:14 PM
Speedklix's Avatar
haven't actually seen it in a corolla but could be time for a new ignition switch at that age maybe.
-EDIT-
ohh yeah, and when my friend's starter died (also a 95) it started to crank slightly slower than ussual, and then suddenly wouldn't at all, but the lights still dimmed a bit.
I would start by checking the signal at the starter to see if the switch is telling the starter to turn or not. if it is, check the cables for the starter, if nothingis loose or rusted to bits replace starter/or have tested at a parts store. if no signal.. probably ignition switch
-Mike
[SIGPIC][/SIGPIC]
