Old 08-19-2007, 08:36 PM
quieter fuel injectors!
does any one know of more quiet fuel injectors? or and way to silence these tickers? can i clean out these by hand, if so how? i've used a few types of additive cleaners and always use cheveron 91oct. but still have a sewing machine under the hood. this really drives me crazy, i've gone so far as to put dynamat all under my hood, for the sake of one more svx in this world please help before i drive her into a wall to collect on the insurance $$$ (totaled svx's don't look as cool!)
Old 08-19-2007, 08:39 PM
Manarius's Avatar
Manarius Manarius is offline
Ticking is usually the lifters - not the injectors.
-Jason
-Obi Wan Kenobi
Old 08-19-2007, 09:29 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Drive it more, run cleaner through them of have 'em sent out and professionally cleaned (recommended by anyone who's done it I've talked to). I have one that ticks like no tomorrow when I fire it up after sitting for a month or two. Valvoline Syncleaner works pretty good on 'em in my experience.
Old 08-19-2007, 09:53 PM
Nomake Wan's Avatar
Retired
The SVX's fuel injectors are much louder than the 90 Legacy's. It was the first thing I noticed when I got it home and ran it. I can confirm that they're the "ticking" noise too, because I used the mechanic's stethoscope on the injectors and sure enough they're what makes that sound...
Old 08-20-2007, 01:21 AM
i used a stethoscope to narrow it down to the injectors too. unless the lifters are under/attached to/super close by, i think it's the injectors. so are the injectors really that hard to clean? it seems like getting them out would be the hard part, which is why i haven't tried to clean them yet, the first one i tried, defeated me. i just didn't want to break one trying to pull it out. can someone please give me a quick over view if they have removed, and/or, cleaned these? thanks.
Old 08-20-2007, 08:58 AM
benebob's Avatar
Hard to clean, no, hard to get off and back on without issue, yes. Seriously if you're gonna pull them might as well have 'em sent out and done right so they meet actual specs. Everybody who I know who had it done say their mileage increases at least 10 percent. Its like 10-15 an injector. Best bet is to pick up some used ones and send them in.
Old 08-22-2007, 12:33 AM
crotchrocketony's Avatar
crotchrocketony crotchrocketony is offline
try running a thin oil and some MM oil in it.....I have heard tons of noist lifters in these SVXs but never a noisy injector. I had a issue like this and it was a shop putting to thick of oil in it. the right oil fixed it!
1992 SVX black/redish 62k awd, rims, brakes..and a few add ons for extra HPs
Old 08-22-2007, 05:43 AM
dcarrb dcarrb is offline
I'm trying to think if I've ever heard a Subaru that at idle DIDN'T sound like a sewing machine. Mine click and tap faintly, contentedly, and this strikes me as perfectly normal.
dcb
Old 08-22-2007, 06:44 PM
immortal_suby's Avatar
Thread Killah
dcb
Locker Link
2015 BRZ Limited 6MT
Old 08-22-2007, 07:42 PM
clicking/tapping faintly would be lovely, but the exhaust and normal engine noise being drown out by the sewmaster2000 is not cool. this is the second motor i have had in this car and i know the first was not close to this loud. also my 05LGTlim. doesn't tap and click, just nice and quiet with the occasional whirling of the turbo, i can't complain about that.
Old 08-22-2007, 07:48 PM
Old 08-22-2007, 07:52 PM
Thread Killah
Wasn't it Beav who coined the phrase, "The SVX motor sounds like a sewing machine on crack"
On both of the svx's I've been with the injectors seemed louder than the motor at idle. I also have put in a brand new set of injectors that I bought as new old stock and they clicked just as loud. Currently I am running 370cc nissan injectors and, you guessed it, they are louder than the engine at idle.
My solution; louder exhaust
Locker Link
Old 08-22-2007, 09:44 PM
Speedklix's Avatar
Locker Link Solution
on a few of my subaru engines I have replaced the o-ring on the oil sump while I had the oil pan off. Helped with ticking quite a bit on two of them.
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 08-23-2007, 06:25 PM
dmnknightomega6 dmnknightomega6 is offline
I had a sticking lifter... Seafoam, And cleaner better gas. It went away.
I also used lucas magic something...... Worked like a charm
Our cars are *****y princesses' give them cheap booze and they will treat get cranky.
Old 08-24-2007, 09:11 AM
benebob's Avatar
Lifter noise is something that has been around in Subies for as long as they've used H engines. Best thing for it if it is simply a sticky lifter is Risoline or Valve medic (80% risoline). Made specifically for going into the oil without any side effects. Have never heard anything bad about Seafoam but I still don't know exactly what is in it as its privledged info.
