Old 08-18-2007, 12:08 PM
svxash's Avatar
svxash svxash is offline
How to OHM test a knock sensor?
So I replaced the knock sensor and the old one looked fine. No cracks or anything. How do you test the ohm's on a knock sensor. There is only one wire in the pigtail.
1997 Boudreaux LSi
1994 SVX LSi(SOLD)
Kool Blue air filter, 4500k HID's, airbox mod, Hella horns, WRX 6 disc stereo, Infinity Reference and Clarion Pro Audio speakers, Infinity basslink sub, ECUtune Stage 1v5, ECUtune TCU, Power mode mod, Mad muffler mod v1.3
Old 08-18-2007, 06:35 PM
The internal circuit is between the pigtail terminal and ground, i.e. the body of the sensor. Resistance should measure around 550K ohms.
I would presume that you replaced the sensor as a result of detecting a fault code. This would be registered in the event of an electrical fault. However the device does have a mechanical aspect, therefore there is the very unlikely possibility of a non electrical fault, which a resistance test will not disclose.
Old 08-18-2007, 10:47 PM
svxash's Avatar
I tried using a ohm meter and connected it to the pigtail and to the metal part of the sensor but didn't get any kind of a reading.
1997 Boudreaux LSi
1994 SVX LSi(SOLD)
Old 08-18-2007, 11:11 PM
probobly why you were throwing a code
