Old 08-02-2007, 09:10 PM
dmnknightomega6 dmnknightomega6 is offline
HID Conversion Issues
Okay.
I bought a Ebay HID Ballast KIT complete with everything ya need.
Pliugged it in. nada.
Tried it on my brothers Accord. Worked Fine. My bulbs still worked fine.
Tried in on A Celica. Worked Fine.
Tapped it directly to the SVX Battery. Worked Fine.
Took out the plugs, Soldered the harness. Nada
Voltage Reading on The Battery to power Supply -- 12.13
Supply - ballast - bulb plug - 0.0
WTF is going on. I am at wits end here.......
Thanks in advance.
Old 08-03-2007, 03:14 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
I don't know if this will help you, but the SVX front lights are earth-switched, which is not like most other cars - so you may have to do the wiring differently.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 08-03-2007, 07:40 AM
earth switched? what in the world is that?
thanks
maybe the grounding is different
Old 08-03-2007, 02:33 PM
ZMan's Avatar
ZMan ZMan is offline
Earth is another term for ground. Earth switched means positive is always supplied to the headlight - when you switch on the lights you are completing ground.
Old 08-03-2007, 03:26 PM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
You have to reverse the pins on the 9006 connector for them to work. It is pretty easy if you've worked with pins before.
Some ballasts work with either polarity, some don't.
Doug
1994 LSi (4/93)
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Old 08-07-2007, 04:23 PM
Reverse Pins: Switch the [positive terminals to Negative and vice versa?
Do i need to rewire due to the earth grounding?
Someone please explain the difference or illustrate the difference in wiring to other cars
Old 08-08-2007, 08:56 PM
hey i just bought an ebay hid kit too. i was also stumped for about 30 mintes when i tried to plug and play but nothing happened. yeah, they're right the positive and negitive are backwards is what i figured out. it was a 1 minute fix though, the plug that goes into the ballast from the car, i flipped around(just had to cut off 2 little plastic snaps) and wallah, works perfect. not too sure if this is the electrically corect way but my light see 3 times further now!
Old 08-09-2007, 08:37 AM
mohrds's Avatar
Electrically correct. However removing the snaps may lead to the plug becoming loose. If I remember correctly, there is a retension ring on the plug and the pins are held in with a spring tab. The come out pretty easy once you look closely at it.
The issue is that before HIDs, there was no positive vs. negative concern for filament bulbs so the factory could do them however they saw fit. It really has nothing to do with the earth switching, the earth switching requires less wire than the older, positive switched lights so it was a cost saving measure.
Normal 9006 filament bulbs will work perfectly with the pins reversed so removing the HIDs before a sale and putting regular bulbs back in will be no problem.
Doug
1994 LSi (4/93)
2000 Ford Excursion
Old 08-09-2007, 09:01 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Doug
Doug,
The only good language is a dead language?
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 08-09-2007, 10:08 AM
mohrds's Avatar
Originally Posted by SVXRide
Doug,
-Bill
Latine loqui coactus sum
1994 LSi (4/93)
2000 Ford Excursion
Old 08-09-2007, 10:14 AM
SVXRide's Avatar
I really don't want to hear about your compulsions
-Bill
Old 08-09-2007, 10:19 AM
mohrds's Avatar
-Bill
Ventis secundis, tene cursum
1994 LSi (4/93)
2000 Ford Excursion
Old 08-09-2007, 10:24 AM
SVXRide's Avatar
Always!
Aequam memento rebus in arduis servare mentem
-Bill
Old 08-09-2007, 10:29 AM
mohrds's Avatar
Always!
-Bill
That is the dumbest peice of wisdom I have ever received
Cogito sumere potum alterum
1994 LSi (4/93)
2000 Ford Excursion
Old 08-11-2007, 01:52 AM
Therefore:
If I reverse the polarity, It really does not matter. It will solve all my problems. I will try this by the week end
thanks guys!!
Veritas Libris
(just to get into the spirit)
