Old 08-02-2007, 05:40 PM
kwren's Avatar
kwren kwren is offline
Exclamation Idler pully for alternator and power sterring belt?
are the adjustment parts pressed into the bearing of the idler pulley from either side. How does it come apart>> The new idler pulley looks different from the origional??
Thanks
Old 08-03-2007, 09:29 AM
kwren's Avatar
Help Anyone ever did this job!
Originally Posted by kwren
are the adjustment parts pressed into the bearing of the idler pulley from either side. How does it come apart>> The new idler pulley looks different from the original??
Thanks
The idler for the ac "froze up" and of course destroyed the belt I changed that one easy but the power steering one looks a bit strange.
Old 08-03-2007, 09:37 AM
I have never replaced the bearings. I have just changed the idler itself.
Get that thing fixed and come over to the Dabob Seafood Meet this Saturday! We are going to have 12+ cars here and a rally on Sat. Great fun, SVX fun, and lots to eat.
Old 08-03-2007, 02:23 PM
kwren's Avatar
that is what I am doing the pully.
Does the mounting bracket just press out of the old pulley and press into the new pulley??
Thanks
KWren
Old 06-01-2010, 09:52 AM
doug maire doug maire is offline
keystoneaz
Re: Idler pully for alternator and power sterring belt?
The adjustment bracket is not pressed in to the idler pulley but may become lodged over time. Remove the nut and washer on the face of the idler bearing and then remove the idler bearing along with the adjuster. Take a punch or a large screwdriver and remove the adjuster by striking the adjuster shaft at the center of the bearing, it should come out easily. after you remove the adjuster clean it up with a wire brush and it should slide easily into the new bearing.
Old 06-01-2010, 10:15 AM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Hopefully he already figured it out in 34 months
Old 06-01-2010, 10:38 AM
keystoneaz
Wasn't really meant for him but for anyone else that does a search of the same problem in the future.
