Old 07-27-2007, 08:41 AM
SVXgarcia SVXgarcia is offline
Send a message via AIM to SVXgarcia
misfiring? other possible problems?
Ok here's the deal. Nothing was wrong with the engine until it was switched over to another SVX. Everything worked well no loss of power or misfiring.
The timing, valve cover gaskets, main seals were replaced before putting the engine back in the car
Once the engine was finally on the other SVX there seems to be a misfiring or loss of power only during take off. When idling the car wants to stall but It doesn't. I have changed the spark plugs but no help. No CEL lights or anything else.
What could have gone wrong? If everything was fine until the engine was switched.
Old 07-27-2007, 10:56 AM
I did the following test posted by SVXfiles
"If you want to find out which cylinder is misfiring, while the engine is idling, you can disconnect, one at a time, the fuel injector connections.
If it gets worse on five cylinders, and has no change on one of them, that is where your miss is.
Remove that coil and plug and check it to see if it has spark."
They all seem to make the engine worse there isn't one that has no change.
Old 07-27-2007, 11:13 AM
AlcyoneDaze's Avatar
<-- custom hood ornament
Im just throwing this out there cuz it just happenend to me...
do the code-check and see if there are any stored codes, even if there is not a CEL on your dash
JDM 4.11 Geared Transmission
JDM 'ALCYONE' Rear Panel
JDM 'BOXER' Eingngine Cover
JDM 'SVX' Hood Badge
L-Edition Suede Rear Seats
Old 07-27-2007, 11:48 AM
JaySVX's Avatar
JaySVX JaySVX is offline
check the timing. If you jumped a tooth that may explain your issues.
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
Old 07-27-2007, 09:19 PM
immortal_suby's Avatar
Thread Killah
My dad's svx just started misfiring today
pulling the injector plugs found it was cylinder #2
swapping the coil from cylinder 2 to another cylinder and pulling the injector plugs again narrowed it down to that coil. The misfire (or the no change in misfire) followed the coil. The rubber boot on the coil is in excellent shape so I have to assume the coil itself or the wiring for that coil is bad.
Unfortunately I am in NY and my spare parts are in SC so I have to mail a coil up here when I get back home so he can put in a good coil. But - I just wanted to let you know - svxfiles method of identifying the problem is excellent.
Locker Link
2015 BRZ Limited 6MT
