Old 07-15-2007, 05:13 PM
Rich1225 Rich1225 is offline
Power Window issue
On my front driverside window of my 94 SVX if you hit the power window switch the window will go down but if you try to put it up the window just jumps up and down like something is keeping it from going up. I have took off my door panel but I don't see anything that would cause that. Has anyone had this problem of have an idea what to look at.
Old 07-15-2007, 06:16 PM
redsvx's Avatar
redsvx redsvx is offline
Alcyone ... the brightest star
try taking out the switch assembly and spraying it with an electronic cleaner
that worked on one I had that was a little sticky
92 SVX LS Pearl
94 SVX LSi Barcelona Red
82 Brat 4WD
Bob
Old 07-16-2007, 09:11 AM
Check out the "sleeve lock"
Up top under "How-To" -> Interior -> "window clip"
Some dealers will tell you that the part is not available, give them the part number... It's a few bucks.
If the problem is the regulator itself I may have one to sell. Send me a PM
