Old 07-15-2007, 12:33 AM
jeffast jeffast is offline
I kill more trannies then god
engine reseal question
ok so i replaced the valve cover gaskets on my car a week or two ago along with a plethora of other gaskets and things and now it appear that the passenger side is leaking very fast, like there is a3-4 inch puddle of oil under my car when ever i park. i think i may have over torqued them, is there any easy way to fix this or do i have to pull the valve covers again...arg
1991 xt6 eg33?
1993 gc track car
Old 07-15-2007, 01:45 AM
did you replace the washer seals as well??
Old 07-15-2007, 12:17 PM
longassname's Avatar
Just some dude.
the valve cover bolts have a shank on them, they won't over compress the valve cover gaskets; over torqueing is just bad for the bolts/heads. Like Tom said, if you didn't change the gaskets on the bolts they are probably leaking for just that reason--the shank on the bolts won't let you tighten down on the already compressed gaskets, they have to be new.
Old 07-15-2007, 11:28 PM
crap tastic, any idea how much they cost dealer list
1991 xt6 eg33?
1993 gc track car
Old 07-16-2007, 05:17 AM
Jeff,
If it's leaking that bad, one of the gasket may have become unseated during install.....might want to pull that side back off and check it.
As for the bolt gromments, a cheap alternative is to install a 0-ring under each old one to seal them...
See ya this weekend at the Dragon!
Old 07-16-2007, 08:57 AM
Jeff, also, they're the same round gasket that is on EJ engines, and I think the same as EA82's also??
Old 07-16-2007, 11:01 AM
They are....I've bought aftermarket EA82 valve cover gaskets just for the gromments before....
Old 07-17-2007, 12:10 PM
ok... so it mysterously stopped...
i've been checking evrey place i park before and after religousely and keeping an eye on my oil level... hasn't lost a drop since then.... i've never seen that before...
1991 xt6 eg33?
1993 gc track car
Old 07-17-2007, 12:38 PM
probobly because your gaskets are blown up like a balloon from all the oil they absorbed... Keep a close eye on it
Old 07-17-2007, 01:31 PM
don't worry i will can't affored for this car to break down right now
1991 xt6 eg33?
1993 gc track car
Old 07-18-2007, 01:20 AM
SVX92-97's Avatar
SVX92-97 SVX92-97 is offline
Arrow Valve cover grommets
If you buy the valve cover grommets, you need 20, 10 per side. List is $3.25 a piece, I got them for $2.50 each, thats $50 + Tax, and well worth it. My covers are now mint, not a drop.
Old 05-18-2009, 10:58 AM
rrhenderson's Avatar
rrhenderson rrhenderson is offline
MacArthur
Re: Valve cover grommets
Where did you find the valve cover grommets? A search for them at subaruparts.com turned up empty. Thanks.
Old 05-18-2009, 02:21 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Subie Dealer.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
