Old 10-17-2007, 03:20 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
Clunking sometimes can be a bad transmission mount if its doing it in reverse.
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 10-17-2007, 03:32 PM
Merz's Avatar
Merz Merz is offline
halfsharkalligatorhalfman
Mine binds in reverse also. When i back out of my gravel drive way onto the street, one of the rear wheels will actually spin on the gravel because the binding is so bad. Definately not the tranny mount.
Im interested in what bruce was asking. My fwd fuse works intermittently also.
`92 pearlie 220k
Tranny Cooler, shift kit, stage 1v4, d/s rotors, axxis pads, Perrin Pulley
'00 GMC Sonoma ZR2.
Old 10-17-2007, 03:59 PM
crazyhorse's Avatar
242,000 mi on oem trans
OK...Torque Bind is caused by the transfer clutch sticking closed. Pure & simple.
The complexity comes in the WHY the clutch is sticking. There are a few causes of this:
#1, Duty Solenoid C. Could be dirty/sticking, if you put the FWD fuse in & it doesn't help, this is most likely the culprit. Not always, but most often.
#2 Transfer clutch welded closed. This is caused by ignoring Torque bind, and/or running mismatched tires, for a prolonged period of time. The plates are actually fused together.
#3 TCU problems. This is the least likely cause.
A few quick tests, and one "what have you got to lose" fix.
Test #1 Insert the FWD fuse, if the bind goes away, your solenoid is most likely ok.
Test #2 On level pavement turn some tight, slow circles. The car SHOULD move at idle with the wheel just off full lock. If it takes a slight, to moderate rise in idle speed to move, your clutches are sticking. If it takes mashing the gas, you may be too late.
"What do you have to lose fix". Flush your tranny fluid. Drain the old fluid, refill, drive it around the block, repeat 3X. If the binding has just started, this can break the clutches loose, or dislodge some grit from the solenoid.
How do I know this? My Leggy tried to start torque binding, and I did my research over at USMB. I was fortunate, in that flushing my fluid fixed my torqe bind.
"42"
Current Stable By Age:
Old 10-17-2007, 06:47 PM
Wocketman Wocketman is offline
Ah, so.
Good info. Sounds like I need to go back to the shop...they checked the duty solenoid last year and said they thought it was ok. But it was stuck in AWD soon after that. With the clunks/clicks I'm hearing (front and rear), I probably have other issues too. Sigh. Looks like I'll be late with the mortgage again!
Bruce Schwab
Recovering solo ocean racer
www.bruceschwab.com
On land: 92 Ebony SVX, 188k
Old 10-18-2007, 06:52 AM
crazyhorse's Avatar
Having the FWD fuse in and intermittently having the binding issues, leads me to believe the Duty C solenoid may be bad, or a possible wiring issue. Especially in a rebuilt trans. The wires can get pinched in the clutch housing during reassembly.
"42"
Old 11-25-2007, 05:03 PM
siceclipse's Avatar
siceclipse siceclipse is offline
Same issue for me.
while going in reverse and turning the wheel the rear makes a clunking sound like something is binding in the driveline.
I hope to find the problem to be a simple one.
Mike
1992 SVX LS-L Pearl White 102,000 miles (Gone)
2005 Evolution 8 SSL Tarmac Black (new daily)
1995 Eclipse GSX Durango Copper Pearl (teh beast)
276awhp/280awtq @ 18psi (560's inj)
260awhp/260awtq @ 17psi (stock inj)
Old 11-25-2007, 05:46 PM
crazyhorse's Avatar
I'm no SVX specialist, and what I know of torque bind, is from my Legacy with an open rear diff. In reverse, my Legacy's symptoms were exactly the same as forward. It was like the brakes were dragging.
COULD the LSD cause a minor binding in reverse? Added to this weak differential bushings making the diff itself "clunk" in it's mounts?
"42"
Old 07-21-2008, 03:49 PM
Schralper's Avatar
Schralper Schralper is offline
Re: binding problem - i know i know....
Resurrecting here,
becuz while i was just testing a different tcu w/ a 6 mile drive.
I found the car was BINDING bad on slow speed turns but right hand in particular.
To the point where it felt like the ebrake had been applied and i had to giv'er gas.
Since this was the only change, i just swapped back to my original tcu and absolutely no binding at all. Even @ full lock.
though i used to have chatter from synth diff oil. i just put in some sliplock and no chatter.
WFO!
http://www.cardomain.com/id/Schralper
"You all laugh cuz I'm different
I laught cuz you're all the same."
