Old 07-05-2007, 08:40 AM
richardstanley's Avatar
richardstanley richardstanley is offline
Lover of Alcyones
5 dummy lights?
Driving my svx home this morning, and at a light i noticed i had 5 dummy lights? Steering, battery, brake lamps (or whatever) brake, and ABS.
Immediatley shut her down and checked under the hood... No loose connections, belts are in great shape, and are tight... Ugh, the power steering and brakes both work, was using a bunch of electrical stuff at the time with no problem.... Nobody here to check if my lamps arent working.
Took the negative off for half hour and they're still all on...
Any suggestions?
Current:
95 svx Ls-L (Black)
91 5sp awd xt6 (red)
Had:
91 xt auto awd(lt blue)
85 xt 4wd turbo 5sp(blue/white)
86 xt 2wd turbo 5sp(black)
85 xt 4wd turbo 5sp(silver/white)
89 xt AWD 5sp (white)
85 xt 4wd turbo 5 sp sold to Zukiru (silver)
86 xt turbo 2wd 5sp (silver/black)
Old 07-05-2007, 08:48 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
It's a common problem. It's probably the rectifier in your alternator.
http://www.subaru-svx.net/forum/showthread.php?t=21852
http://www.subaru-svx.net/forum/showthread.php?t=34652
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 07-05-2007, 11:29 AM
Yep...time for a new alternator
Old 07-05-2007, 12:55 PM
Lover of Alcyones
Yep time for a new alty
I messed around with it a bit today and they all went off. So at least now i can save some money for a new one lol.
Current:
95 svx Ls-L (Black)
Had:
Old 07-05-2007, 01:53 PM
wynndi's Avatar
wynndi wynndi is offline
Send a message via AIM to wynndi Send a message via Yahoo to wynndi
Alternator time!
Dave W.
______________________________
1996 Redd
Old 07-05-2007, 07:19 PM
Definitely the alternator!
I had the exact same problem. When idling at night with the lights on (750rpm) the dummy lights would start to glow faintly. If I raised the rpms a little or turned off the lights, they went out. Checking them with a voltmeter, the lights started to glow when the voltage was 11.5V
I replaced the alternator with a new Subaru one and all the problems went away. Idling now with 13.9V.
Old 07-05-2007, 07:26 PM
The dash indicator lights test circuit, incorporates blocking diodes to eliminate a sneak circuit which would otherwise exist. In an event involving faults within the alternator rectifier network, alternating current is induced on line. The result is pulses of reverse voltage, which pass the blocking diodes in the test circuit and energise the indicator lights.
Old 07-07-2007, 11:26 AM
kwren's Avatar
kwren kwren is offline
Have you tried taking out the bulbs??
Just kidding!
Trevor is right........ whatever he said!
Translation... TIME FOR A NEW ALTENATOR!
Old 07-07-2007, 12:23 PM
Just kidding!
I would rather put in a new alternator than take out those little bulbs behind the dash!
