Old 06-21-2007, 09:42 AM
DanSVX94's Avatar
DanSVX94 DanSVX94 is offline
Ren-Ma Osu
How to install computer
I bought a used computer to replace the one in my car. Does anyone know how to install it? Any special procedures? Thanks.
Used to have: 1994 Pearlie, 40,945 miles, PWR Radiator, Motorsports Aluminum Crank Pulley, Raceconcepts Stainless Brake Lines, Axxis Ceramic Brake Pads, ATE Super Blue Racing Brake Fluid, Dimpled/Slotted Rotors, BBS STi 17 Silver Wheels, Toyo Proxe4 225/45/17 tires, New Dekka Battery, Unauthordox Racing Oil Cap -- adds 3.14 hp, OEM Coin Holder FFTDS aka Force Field Theft Deterent System. Magnetic oil drain plug, Purolator larger oil filter. Now she's in good caring hands at Earls place.
Old 06-21-2007, 09:50 AM
RSVX RSVX is offline
Network Design Administrator
Could you be a bit more specific?
Install what? The operating system? Or just set it up and turn it on? Software?
You really dont have enough info here for us to help.
Life is a game. Play to win.
Old 06-21-2007, 09:56 AM
I'm going to assume that you mean the ECU??
-Undo the battery.
-Remove the ecsaine trim under the steering column
-Look up underneath to the left of the column and you will see the TCU and ECU bundled together. The TCU has black plugs, the ECU has yellow
-They are held in place with 3-10mm bolts. It will take a variety of extensions, wrenches and some imagination to get them.
- Re-install, one or two of the bolts have slots rather than holes, so you can getthem started before you put the *CU's in place
-Take some advil and lie flat on a heating pad.
Old 06-21-2007, 10:45 AM
Sov13t's Avatar
Sov13t Sov13t is offline
Whatever you do... do not run Windows on it!!!
Subaru SVX 94' Laguna Blue - 8.5 C/R Built Motor, 6spd
Old 06-21-2007, 11:09 AM
-Undo the battery.
Wow, thats what I get for being an IT guy, LOL!!! I didnt even notice the section!!
Oh well, I will leave that all in place for everyone to laugh at me, because, well... I deserve it after that one...
Old 06-21-2007, 02:08 PM
It was funny. It was true he needed to be more specific since there are several units he could have been referring to. With the speed of the ECU you probably wouldn't want to install anything newer than Windows 2.0 on it
Old 06-21-2007, 02:25 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Another point - don't worry about using all three bolts when you put everything back together - too much of a PITA and two bolts do just fine.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 06-21-2007, 05:08 PM
Sov13t's Avatar
-Bill
+ less weight I am sure thats why you suggested that, right?
Old 06-21-2007, 06:04 PM
This is true.
SOME people leave their nuts in a jar by the door, just to go racin!
