Old 06-12-2007, 07:51 PM
low$svx low$svx is offline
Can't get it to start
I just picked up this 92 svx and it supposedly ran when the guy parked it, blah, blah,blah, but the price was right. Anyways it turns over fine, gets spark, and you can smell fuel in the exhaust. The timing marks on both cams are lined up but I am unaware of the crank, due to the fact that I can't see it. Does anyone have any ideas? I am getting ready to sell it but figured try asking as my one last effort. I am good with cars but don't know to much about how the svx works, cause there is so much experimental I guess you could say stuff on it. Thanks for your help in advance.
Old 06-12-2007, 08:07 PM
Well, if it has spark, and fuel, and air, and is in time, it should run....
Does it have compression?
How old is the fuel in it?
Make sure you have a good battery in it.
Old 06-12-2007, 08:16 PM
1.Compression seems to be fine.
2. Fuel is not very old at all.
3. Brand new battery and cables.
I figured if it has all that it should run too. Is there anyway to check the afm or maf, whichever one it has, to see if it is bad?
I am just dumbfounded. That is really the only thing other that the computer that I think it could be. I just don't know
Thanks
Old 06-12-2007, 08:31 PM
Is the Check Engine Light on? If it's a 92-95 you can check the codes yourself following the procedures in the "how-to" at the top of the page.
Old 06-12-2007, 11:47 PM
I think it is on but doesn't it have to be running in order to pull a code?
Old 06-13-2007, 05:01 AM
Not to pull stored codes...
Old 06-13-2007, 05:12 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
cam sensor, crank sensor, water temp sensor...the car won't start if any of these are bad....
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 06-13-2007, 07:21 AM
Will the codes still be there if the battery went dead?
I replaced the cam sensor, and the top crank sensor tested out to be fine. Is there a crank sensor underneath the car? The chiltons said it had 2 crank sensors and 1 cam sensor. Is that true? I am getting spark so would all those sensors be fine?
Old 06-13-2007, 08:04 AM
Both Crank sensors are right next to each other, under the alternator
Old 06-13-2007, 09:05 PM
Does anyone now if the sensors talked about above would keep it from sparking or keep it from doing something else? I am getting spark so are all of these sensors good? Even though I am getting spark could they be causing a problem somewhere else?
Old 06-13-2007, 09:42 PM
cdvs cdvs is offline
If you have spark, it's very likely a fuel problem. Try some starting fliud.
Good luck.
Old 06-14-2007, 05:06 AM
As He said /\, if you have spark, it must not be ignition related, so those sensors should be fine...maybe the fuel pump is shot...
Old 06-14-2007, 07:23 AM
just wanted to let you guys know that I did fire a few times on the starting fluid. So if any one has info on the location of the fuel pump, please let me know. I have to go to work but after I get home I should be able to check the fuel system.
Thanks
Old 06-14-2007, 08:07 AM
The Fuel pump is in the tank, but can be accessed from either the trunk floor, or under the back seat....I don't remember which on the SVX
Old 06-14-2007, 08:50 AM
Before you tear into the tank, check for fuel at the fuel filter under the hood, next to the drivers side strut tower.
