Old 06-12-2007, 12:08 AM
SubaRyu's Avatar
SubaRyu SubaRyu is offline
Domo Arigato
Adjusting Idle RPM?
Does anyone know how to adjust idling RPM? Mine seems bit low and I'd like to increase up to 600 or 700rpm. Is it easy or gotta get some new parts??
Thanks.
-Ryu
Links:
2004 Honda S2000 (2008~)
1992 Subaru SVX LSL Liquid Silver (2007~2008)
1996 SVX LSi Bordeaux Pearl (2006~)
2002 Lexus IS300 Sportcross (2005~)
1992 Subaru SVX LSL Pearl White (2001~2005)
1994 Mercury Sable GS (1999~2001)
1/43 Scale SVX Models
[SIGPIC][/SIGPIC]
Old 06-12-2007, 02:58 AM
Ryu
When you say it's low, I must presume less than 600 rpm.
If it is not causing the car to cut out, why would you want to up it? Or is the car cutting out?
Old 06-12-2007, 01:52 PM
SubaRyu's Avatar
Domo Arigato
Originally Posted by svxistentialist
Ryu
Yup, it's about 500 or less RPM. When approach to stop sign it "almost" cut out. Never cut out yet, but not surprising if it did.
-Ryu
Links:
[SIGPIC][/SIGPIC]
Old 06-12-2007, 01:56 PM
SubaRyu's Avatar
Domo Arigato
Ryu
One more thing.. when A/C is on, RPM is slightly higher, so no problem...but I'd prefer fresh summer breathe from window you know...
-Ryu
Links:
[SIGPIC][/SIGPIC]
Old 06-12-2007, 02:52 PM
Manarius's Avatar
Manarius Manarius is offline
The RPM is supposed to be higher to account for the A/C being on. That's normal. On the EJ22 (the engine in the Legacy), there's an idle adjustment screw located right where the throttle body meets the intake. I'm pretty sure there is one in the SVX located in a similar place. tightening the screw should raise the RPM slightly. You might also want to consider cleaning the Idle Air Control Valve.
-Jason
-Obi Wan Kenobi
Old 06-13-2007, 01:00 AM
SubaRyu's Avatar
Domo Arigato
Thanks I'll look into that. If I can't find it, might ask you for some visual help
-Ryu
Links:
[SIGPIC][/SIGPIC]
Old 06-13-2007, 08:00 PM
immortal_suby's Avatar
Thread Killah
it would be new to me. As far as I know (and what is stated on the underhood label) the EG33 idle is not adjustable. It does go up with the AC on, but AFAIK you can't adjust it. You could adjust your throttle cable linkage to raise it up.
I'll check the service manual to see if I can find something that says otherwise. LAN could most likely tell us if it is something in the ECU or in the IAC that sets where it will be.
Locker Link
2015 BRZ Limited 6MT
Old 06-13-2007, 08:41 PM
Kelvin Kelvin is offline
Banned
Indeed. That helps, and it makes the car a bit more responsive, but it will ding your MPG a little bit, if you are ever idling, it uses more fuel.
Old 06-13-2007, 09:13 PM
Check for any vacuum leaks or disconnected hoses. Last time I had my intake snorkus off/on I forgot one hose causing the car to idle very low.
Also make sure it's not pinched in the throttle body.
Another thing to check is that all the intake plenum bolts are tight.
Old 06-14-2007, 12:42 AM
SubaRyu's Avatar
Domo Arigato
Yup pretty sure the vacuum hose/air filter box are tight. I checked w/ mechanic. Unfortunately when he was test driving the low RPM symptom didn't show...so he couldn't find out what was wrong. I thought it was just RPM adjusting.
-Ryu
Links:
[SIGPIC][/SIGPIC]
Old 06-14-2007, 12:54 AM
SSSVX's Avatar
SSSVX SSSVX is offline
One teal and One yellow
which one? mileage now?
clean your throttle body, do a seafoam cleaning and put a bottle of fuel injector cleaning into the gas tank. that's what I would try if I were you.
-SSSVX
92 LS-L TEAL since Aug '01
92 LS-L YELLOW since Mar '05
Old 06-14-2007, 05:08 AM
Banned
Check for any vacuum leaks or disconnected hoses. Last time I had my intake snorkus ...
I'm pretty sure that's the technical name, too.
Old 06-14-2007, 11:40 PM
SubaRyu's Avatar
Domo Arigato
It's my '92. my '96 doesn't have any problems like that. Funny they both have almost identical mileage now. Around 112K mi.
-Ryu
Links:
[SIGPIC][/SIGPIC]
Old 06-14-2007, 11:41 PM
SubaRyu's Avatar
Domo Arigato
Is 400 rpm low or what... Engine is warmed up. When AC is on, it's like 600 or 700 RPM.
-Ryu
Links:
[SIGPIC][/SIGPIC]
Old 06-15-2007, 03:30 PM
Manarius's Avatar
400rpm is what I get on my EJ22 when it's warm. It's more like 1000 though when the AC is on.
-Jason
-Obi Wan Kenobi
