Old 06-14-2007, 08:52 AM
Kelvin Kelvin is offline
Banned
I fixed mine. I'm not crystal clear on remembering how I did it, but it involved some gel superglue. Take it apart, glue the busted parts together, and it should work again.
Old 06-14-2007, 10:44 AM
I have a couple of broken ones. I will have to try the superglue method.
Old 06-14-2007, 04:43 PM
I've glued mine as well and it's been working fine ever since. The stuff to watch out for is breaking the pieces off again when reinstalling the buttons. I'm also very gently with the switched and make sure to use only the force necessary to operate the windows.
Old 06-14-2007, 07:33 PM
XT6Wagon XT6Wagon is offline
On a older subaru it started to not work, and the cause was the inital contact would arc a bit and over the years the build up of soot made the switch not work right.
Old 06-14-2007, 07:59 PM
cozykat's Avatar
cozykat cozykat is offline
Still rebuilding my block...
Alcyone Silver Contributor
Originally Posted by ensteele
If you mean repair the switch if it is broken, someone has. They are no longer here, but they figured out how to do it. I don't know how, because they would not share the secret. They were fixing them and charging for the repairs. I have a couple that are broken and I have not had a chance to try the fix yet.
I recently had my driver's side switch stop rolling down the passenger window. I plan on taking my door apart to see why. I have bypassed the switch a few times inorder to run some experiments so I think my issue is with my lines (I think I have a loose connection). Electronics being my field, I could always take a look at someone's broken switch and see if I can repair it. I am trying my best to remember what I saw when I took the switch completely apart 9 months ago but my memory is getting fuzzy. If I am wrong about the wires on my switch I might take the switch apart and verify its not the switch. I guess I better go find my pictures and notes from when I took apart the switch.
take care!
Marisa
Old 06-14-2007, 08:22 PM
cozycat, let me know how it goes, as thats one of the many things my SVX has decided to inflict on me in its bid for attention.
Old 07-30-2007, 11:45 AM
AlcyoneDaze's Avatar
<-- custom hood ornament
im replacing my drivers side switch assembly tomorrow or today... any tips on removing the four switches without damaging any of the surrounding trim? I see the screw cover under the door latch, and the screws under the felt/cloth piece. any others?
JDM 4.11 Geared Transmission
JDM 'ALCYONE' Rear Panel
JDM 'BOXER' Eingngine Cover
JDM 'SVX' Hood Badge
L-Edition Suede Rear Seats
Old 07-30-2007, 12:42 PM
dcarrb dcarrb is offline
Originally Posted by AlcyoneDaze
any others?
You have to remove the entire panel. Two screws hold the front edge of the interior door panel to the door. They're exposed when the door's open. Once you have all the screws out, pop the bottom loose and lift the whole thing upward, then unplug the power leads. Two or three screws hold the 4-switch assembly to the inside of the door panel; it's easy. The only minor hassle is lining-up the door lock when you go to replace the door panel. Use a magnetic-tip screwdriver to replace that little screw underneath the door handle.
dcb
Old 07-30-2007, 12:52 PM
wait, i have to remove the entire door skin to get at it?
any threads with pix?
Old 07-30-2007, 01:11 PM
Banned
Yeah, you have to remove the whole door interior panel. It's somewhat of a PITA, putting it back on. Taking it off is no big deal.
Old 07-30-2007, 01:30 PM
If you've been wanting to replace that door speaker, now would be an ideal time.
Really, I've had the door panels off both of mine several times, and it's no big deal. And believe me, I'm no mechanic. Once you have the screws out, it just basically pops off. Replacing it, just hook it at the top, align the lock button, ease it downward, align the snaps at the bottom and pop it back into place. Then replace the screws. That little snap-cover-dealie under the handle gives me more trouble than anything.
dcb
Old 07-30-2007, 01:44 PM
gotta do whatcha gotta do i suppose. thanks for the input. i'm not half bad at reskinning doors actually, i've done ****e like this before
Old 07-31-2007, 05:33 AM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
take care!
Mine just started doing this last week. The passenger switch brings the window up right away, but the master switch for the pass. window will not bring the window up anymore.
I'll take some pictures when I take mine apart next week or this week. I think the plastic switch pivot might have broke.
1995 Subaru Svx L / AWD
Old 07-31-2007, 08:56 AM
I got a brandy new switch on order from subaru, and my door skin is already leaning on the garage wall. It wasnt all that hard to take off, just had to make sure all the screws were out before doing any yanking...
Im gonna change the LED in the switch from green to red... pimp!!!
Old 07-31-2007, 09:33 AM
Banned
I thought about doing that too... but instead I just wrapped it with tin foil so it's brighter (ghetto in switch reflector).
