Old 05-27-2007, 06:36 PM
jman050's Avatar
jman050 jman050 is offline
Its a Classic!
adjust headlights
one of my headlights is off and when i adjust the screw on the leveler (glass bubble thing) it doesnt seem to have any affect on the aiming of the headlights. Is there any way to physically adjust the level of the headlight?
jason
[SIGPIC][/SIGPIC]
Old 05-30-2007, 04:42 PM
jman050's Avatar
Its a Classic!
i cant believe noone has had to actually adjust their headlights
[SIGPIC][/SIGPIC]
Old 05-30-2007, 05:02 PM
SVX_MY_BABY's Avatar
Do a search. I posted detailed instructions less than a year ago.
Old 05-30-2007, 10:18 PM
The adjustment that you seem to be using is to level the bubble. If you have trouble finding the thread that gives details, let me know and I will help you.
Old 05-30-2007, 10:24 PM
OK, here is the answer that SVX_MY_BABY posted.
Here's what Subaru and Chilton say.
1. Park vehicle on level ground about 25 ft. from a flat wall and remove any heavy objects from the cargo area.
2. Check tire pressure is correct.
3. Make certain that the vehicle's gas tank is full and that someone is seated in the driver's seat.
4. Bounce the vehicle several times to normalize the suspension.
5. If not using the gauges switch on low beams. The vertical height of the light beams above the ground should be 4 in. less than the distance between the ground and the centre of the lamp lenses for the lights.
6. Use a suitable wrench or socket to adjust the level indicator nut at the end of the level.
7. If using the level the bubble should not deviate from centre of the sight glass more than 2 marks vertically and one mark horizontally.
Old 05-31-2007, 03:33 AM
jman050's Avatar
Its a Classic!
Thanks!! this nut seems to be what ive been missing. Now lets see if i can find it
[SIGPIC][/SIGPIC]
Old 06-12-2007, 08:05 PM
I guess you've found the nut
I wouldn't go by the bubble method...only because both on mine are broken
Old 06-13-2007, 12:05 AM
The only thing that the bubbles are used for are a reference point.
Old 06-13-2007, 01:22 PM
SubaRyu's Avatar
SubaRyu SubaRyu is offline
Domo Arigato
I used a power screw driver to adjust mine. Made my job so easy and quick...
-Ryu
Links:
2004 Honda S2000 (2008~)
1992 Subaru SVX LSL Liquid Silver (2007~2008)
1996 SVX LSi Bordeaux Pearl (2006~)
2002 Lexus IS300 Sportcross (2005~)
1992 Subaru SVX LSL Pearl White (2001~2005)
1994 Mercury Sable GS (1999~2001)
1/43 Scale SVX Models
[SIGPIC][/SIGPIC]
