Pre-Cats
After frying my main cat at Summit Point, I'm thinking it is time to replace the pre-cats also. Magnaflow has a universal fit unit #50004, which says it is suitable as a replacement for the OEM pre-cat and which costs about 1/3 as much. Looking at the diagram on Subaruparts.com, it looks like the O2 sensor mounts just upstream of the pre-cats. Does anyone know whether there might be a problem with pulling out the OEM pre-cat and putting in a replacement? Thanks.
____________________________________________ 95 LS-i Red, 31,xxx; bone stock for now; Daily Driver 94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light, 2017 Subaru Forester XT, metallic dark gray, 29,xxx 2005 Porsche 911 Turbo S Cabrio, 24,xxx 2006 Subaru Outback LL Bean, 166,xxx sold 92 LSL Dark Teal, Smallcar Shift Kit - sold |
I was planning on doing the same with my system, and replacing the main cat with a Magnaflow cat # 94007. The only problem is that the Magnaflow pre-cats are 2" in and out, and their main cat is 2" in, 2.5" out. I think the pre-cat piping is smaller than 2".
I'm thinking of just cutting the pre-cats off from the rest of the pipe, finding the apropriate adapter, and clamping or welding the magnaflow parts onto the old pipes. Or you can just buy some flanges and build your own 2" pre-cat pipes.
Chris 92 Ebony Mica LS-L "A Rolling Restoration": 223,250 KM - Sleeping 2007 STi 6MT, Stance GR+ coilovers, PWR Rad, JDM hood badge, svxfiles 6000K HIDs, JDM Clear Corners, $15/15 min mod, $20/20 min mod, Energy Swaybar Bushings, Hella Supertones horns, Gold STi BBS rims, Group A lightweight crank pulley, A/C system removed, Custom header-back exhaust, Hybrid carbon/metal rear sway bar, restored headlights with CCFL halos 2008 Subaru Legacy Spec B - Diamond Grey Metallic - Sold 2020 Ram 1500 Longhorn - Red Pearl Last edited by Crazy_pilot; 05-27-2007 at 06:11 PM. |
I think the pre-cat piping is the same size as the inlets to the main cat, which is 2". My muffler guy thought I would need the pre-cats to pass emissions.
Right after the header flange they are 2.11" for most of the front pre-cat inlet pipe, it is 1.91" after the pre-cat its pipe is 1.68"-1.61". According to Magnaflow the 94007 is legal in 48 states. Good morning Dan, Pilot.
www.svxfiles.com The first SuperCharged SVX, the first 4.44 gears, the first equal length headers, the first phenolic spacers, the first Class Glass fiberglass hood, the first with 4, 4.44s in his driveway Fiberglass Hood thread My locker 4.44 Swap link Last edited by svxfiles; 05-28-2007 at 08:07 PM. |
Tom:
Thanks for the info. If the connections for the Magnaflow 50004 are 2", I'm sure my muffler guy can make the transition. Do you think there will be any problems with the O2 sensor. How have you been? Hope things are going well for you. Saw your website. Wish I were close enough to give you some business.
PreCats
The oxygen sensors are mounted just a touch over 4" in front of the precats and the precats are 11.5" long. There should be no problems with sensors or mounting as long as the replacement precat is 14" long or less. You might even fit a 15" replacement.
Lee
SVXx2 92 SVX LS-L Silver 92 SVX LS-L Burgundy (structurally challenged with 2792 miles) 96 SVX LSi Red 92 SVX LS Pearl (Parts) 01 F150 4X4 Red (+6 with other members of the family) FREEDOM IS NOT FREE |
Lee:
Thanks for the information. Dan
I will have to have Di spell check AND read for content!
I recently had mine done. #50004, # 94007
Also, I ordered my 94007 yesterday, but the local guys can't get the 50004's except by special order from Summit Racing, and they're back-ordered to mid June.
No flange. I had a bracket welded under the Y-section for support. It's not moving anywhere.
those are the same Pre-cats I had on my old exhaust... Then I killed my cats all together
Tom |
