Old 05-27-2007, 10:39 AM
Traitor_Moron's Avatar
Traitor_Moron Traitor_Moron is offline
BoreD'oh Poseur Faux Pas
Crank Pulley Tool
I have ordered 2 of these crank shaft tools online at $80 a pop. Subaru is unable to tell me which one I need. I cant return the tools and rather than spend another $80, does ANYONE have the tool I can rent?? My mechanic is afraid to use the screwdriver in the flywheel trick. and when I mentioned the flicking the starter method he freaked out.... i just want my oil pump replaced and I cant get it done without this freakin tool!! I think the STUPID Subaru dealer in Las Vegas MUST be Mob owned because when i mention SVX they get this glassy stare and cold sweat. HELP!!
Old 05-27-2007, 08:58 PM
Hop Hop is offline
Classic SVX
I just bought a plain old strap wrench from sears for $10 and did the job myself in my garage. It's not as hard as you'd think. And it's even easier if you have access to an impact wrench. I didn't and still got the job done. Take a little time and check out local import shops. Just call around an ask if they can change timing belts.
Old 05-28-2007, 06:30 AM
jman050's Avatar
jman050 jman050 is offline
Its a Classic!
unfortunately the technique displayed in the above picture didnt work for me. The rubber strap wrench snapped like a little toy ...i ended up using one of those heavy duty canvas strap wrenches. I got mine from snap on but im sure some other companies make them. I also had to use an impact wrench.
[SIGPIC][/SIGPIC]
