Old 05-25-2007, 08:14 AM
SubyLuver SubyLuver is offline
Loyal Subie-ist
Send a message via MSN to SubyLuver
Door sensor
Ok so my door sensor doesnt work at all. (the thing that tells the car the door is open) I think these are in the latch arent they? if so is it possible to replace that, last time I had my door skin off it looked virtually impossible. Any info would be great then I could get my lights and seatbelt workin again
Thanks
Subyluver
'92 Subaru SVX Ebony 216k miles
(Magnaflow Custom Cat-Back, ES Stablizer Bushings, Permacool Relocator, 2.5RS FPR, SS Brake Lines, EBC Green Pads, Raceconcepts D/S Rotors, Pirelli P-Zero Nero M&S)
(To-do list Koni Struts & Springs lacking funds)
Old 05-25-2007, 11:18 AM
JaySVX's Avatar
JaySVX JaySVX is offline
It's a little button type in hte front inside of the door jam. spray it with some lubricant and it shoudl be fine.
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
Old 05-26-2007, 01:54 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
No. SubyLover had it right. It's inside the latch. But it is possible to fix it.
If you remove the door panel, first check the electrical connections on the latch before you go to the trouble of removing it. The latch itself comes out quite easy. Just unclip the rods, undo the screws and the bolt and then out it comes. Open the lid on the actuator and make sure there is no water inside and inspect all the electrical pathways. On one of mine there was a copper track that looked a bit corroded. So I checked it with a meter and sure enough, no continuity. I soldered in a new piece of wire and it solved the problem I was having.
There's some good info on fixing the door locks if you do a bit of searching.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
