Old 05-25-2007, 12:01 AM
svx-t svx-t is offline
whp and torque for stock svx??
like what title says...whp and torque for stock svx?? or with the 5spd?? let me know..thanks!
dao
Old 05-25-2007, 11:20 AM
JaySVX's Avatar
JaySVX JaySVX is offline
Horsepower 230@ 5400 rpm
Torque: 228 @ 4400 rpm
Check out this site for complete specs, trim, years, and models:
http://www.cars101.com/subaru_svx.html
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
Old 05-25-2007, 11:52 AM
Ricochet's Avatar
Ricochet Ricochet is offline
I brought some ham.
He's looking for wheel horsepower. I think it's in the 179 range..
Brian
Old 05-28-2007, 06:33 AM
jman050's Avatar
jman050 jman050 is offline
Its a Classic!
around 165whp with the auto and probably 10-12 more with the 5spd. Im not sure about the torque.
[SIGPIC][/SIGPIC]
Old 05-28-2007, 03:38 PM
Auto is 160-170, manual trans or 4.44 auto should be closer to 180-190. Torque is the same. Numbers for a beat or well-worn SVX will be lower. Since noone has dynoed a fresh engine we can't really say.
Old 05-28-2007, 05:54 PM
N.B. Torque at the wheels at a nominal engine RPM, will vary considerably with any changes in the final drive ratio.
Old 05-28-2007, 06:11 PM
jman050's Avatar
Its a Classic!
the gears wont affect the amount of torque on a dyno
[SIGPIC][/SIGPIC]
Old 05-28-2007, 06:19 PM
If you wish to contradict my statement, please be exact in what you are suggesting.
Old 05-28-2007, 07:34 PM
jman050's Avatar
Its a Classic!
As far as i know unless there is something internally different inside the 4.44 trans that lessens the amount of hp/tq loss from the engine to the transmission there will not be any difference in a dyno reading if someone switches to the shorter gears given the same car, conditions, and dyno.
If I am wrong please let me know
[SIGPIC][/SIGPIC]
Old 05-28-2007, 08:00 PM
Ricochet's Avatar
I brought some ham.
Gears won't change peak power..
Brian
Old 05-28-2007, 11:31 PM
My earlier post:-
If torque readings a taken from the wheels at the same (nominal) engine RPM with alternative gear ratios, the lower the gear the greater the torque at the wheels; e.g. the car could be climbing a steeper gradient at less speed.
At the same time, there will be no change in the power delivered, other than what could be a slight variation due to differing gear friction/losses.
Think on what happens when you select a lower cog on a push bike. You may move forward more slowly but with the same amount of energy (power), you generate sufficient torque at the rear wheel, to climb a hill.
Old 05-29-2007, 01:52 AM
Less [required] effort = more power, in this case.
I was also trying to point out peak wtq and whp would likely be very similar. The crank values are only off by 2 units.
Old 05-29-2007, 06:55 PM
longassname's Avatar
Just some dude.
The values being quoted are high for a stock svx. The 179 whp thrown out was my car which had stage 2 on it at the time. Most awd SVXii dyno in the 150's--some are in the high 140's.
I dyno'd a stock svx recently but I didn't even ask for the file or print out at the time. I just did it for a baseline to overlay the next modded pull over. After the next time I dyno it will show up as the baseline in plots posted on the www.ecutune.com website.
Torque measurements from the dyno can be given as wheel torque or crank torque. If it is given as crank torque it can be calculated based on the gear ratio or an rpm probe depending on the equipment. Often times the dyno print outs are print screens from the monitor display in which case the labels of the boxes are usually incorrect they will say crank or engine but really be displaying wheel values because the dyno operator has zeros entered into other boxes.
Old 05-29-2007, 07:21 PM
If wheel "dyno" equipment, does not directly measure RPM from the engine, any semblance of accuracy is impossible. In any event accuracy is only via hope and wishful thinking. However you will always have to pay.
Old 05-29-2007, 08:51 PM
That sounds about right for 34-35% parasitic loss. I didn't figure any percentage into the numbers I threw out.
I do think I rememeber Chike's car being dynoed in the 160 range with his 4.44. It's hard to remember.
