Old 05-20-2007, 11:21 PM
jeffast jeffast is offline
I kill more trannies then god
4.11 swap shifting, different problem
my car likes to redline the living **** out of second, it wont shift out of second unless i let off of the gas down to less than 2/3 of the way depressed, if i floor it it will down shift even when its past the redline and jerk the car to a lower speed it only does this with second, any ideas?
1991 xt6 eg33?
1993 gc track car
Old 05-21-2007, 12:03 AM
What is involved with this ---- 4.11 swap ----- with valve body shift kit
Have you checked for codes? Check the TPS. Go a little easier on your car.
Old 05-21-2007, 01:02 AM
i forget who makes it, i think small car, it just firms, and speed up the shifts, it required machineing the valve body and replacine a few springs and ball bearings, my local trusted shop reccomended it
the tps is set dead on at 5.2 volts
and i keep forgetting to check tcs codes, i'll do it tommorow
1991 xt6 eg33?
1993 gc track car
1991 xt6 eg33?
1993 gc track car
Old 05-21-2007, 02:29 AM
OK. You have checked the TPS set position, but your fault is more likely to result from erratic contact at the upper end of travel. Have a look in my locker for more advice.
Was the fault noticed a short time after the transmission work? Have you asked your trusted shop about the problem?
Old 05-21-2007, 05:11 AM
Yep, Jeff,
I'd ask the guys at the shop that installed the shift kit, as it could be related to it, before I'd try anything else....asking them should be free, since it's concerning work they did.
Old 05-21-2007, 02:50 PM
they said it shouldn't affect shift points,
1991 xt6 eg33?
1993 gc track car
Old 05-21-2007, 02:51 PM
i'm pretty sure that its not the tps i checked it severial times before i put it in and it tested like brand new, within specs, and went up and down nice and evenly
edit: i bought the car with a blown transmission, it had been sitting for a year or more in a field, it had first and reverse when i started working on it, and i found a 4.11 trannie cheap
1991 xt6 eg33?
1993 gc track car
Old 05-21-2007, 04:04 PM
OK. You are doing all the right things, but as so often, these do not help.
Old 05-21-2007, 10:10 PM
It's Just Eric's Avatar
Missing in action
Send a pm to svxfiles about his transmission resistor modification for 4.11's...Im dont know if that has anything to do with your problem, or if it could remedy it...But he is the guy to ask
R.I.P Cool Signature.
Old 05-21-2007, 11:37 PM
cool thanks i just pmed him
1991 xt6 eg33?
1993 gc track car
Old 05-22-2007, 12:03 AM
The resistor is not involved. Refer my locker where there are details regarding the function of the resistor and the relationsip to solenoid "A" and line pressure.
Old 05-22-2007, 12:09 AM
The kit is most likely intended to raise line pressure at certain points in the hydraulic circuit, in order to increase clutch pressures, as a means of improving issues involving friction.
Old 05-23-2007, 09:40 PM
to add a little more info, the car does stutter a little going from 2nd to third, i've noticed, how bad is this?
1991 xt6 eg33?
1993 gc track car
Old 05-23-2007, 09:51 PM
Engine stutter, transmission slip, torque reaction, delay in shifting?
