Old 05-18-2007, 06:47 AM
Brake Bleeding Kit
Was wondering if anyone has worked with this brake bleeding kit offered by Harbor Freight....Pros/Cons?
http://www.harborfreight.com/cpi/cta...merID=14585525
Old 05-18-2007, 06:59 AM
That's what I use for bleeding brakes. It works great, but, it's hard to get a real tight fitting on the nipple, so you will almost always pull some air into the clear tubing. This doesn't affect the brakes at all. But if you keep pumping till "no more bubbles appear in the line" you'll drain your system.
It also useful for checking vacuum related parts
Old 05-20-2007, 06:46 PM
That's what I use as well. It is a great way to do it. I also like the speed bleeders.
