Old 05-12-2007, 02:57 PM
Mystery Switch and Button
In the process of trying to check the power lock fuse, I found a two way toggle switch and button in the kick panel. The car does have an aftermarket security system installed by a previous owner.
Neither have any effect on how the car starts or runs, and the alarm seems to set regardless of the switch position.
Any thoughts?
Old 05-12-2007, 03:24 PM
UPnorth362's Avatar
UPnorth362 UPnorth362 is offline
Send a message via Yahoo to UPnorth362
The momentary push button has two functions.
1. programming the alarm brain.
2. emergency alarm disarm.
The toggle switch is usually to disable remote start function. Suppose it could depend on the alarm manufacturer.
Looks like it must be a Directed Electronics alarm from the looks of the switches
IT'S 5:00 SOMEWHERE!!!
92 Liquid Silver SVX LS-L
Old 05-12-2007, 03:42 PM
Remote start huh? Would that be what the "AUX" button on my remote is for?
Old 05-12-2007, 04:05 PM
Maybe - try it and see what happens.
Old 05-12-2007, 04:57 PM
Hrmm...no dice. The AUX button only lights up the LED on the remote. It does nothing to the car, wherever the little switch is.
Too bad, remote start would have been nice.
Old 05-12-2007, 06:20 PM
UPnorth362's Avatar
Can you see the alarm brain? If so look and see what brand and model it is. if it is a DEI, the remote start can be set to any # of buttons. I used to set them up where you hold lock and unlock at the same time to start the car. Check it out, and let us know.
Old 05-12-2007, 06:51 PM
SWEET! Lock and unlock together starts it right up!
I have a remote starter...*does happy dance*
Old 05-12-2007, 06:57 PM
UPnorth362's Avatar
SWEEEEETTT!!!!!! Now you just need to do window mods, so when you arm the alarm the windows go up, and the doors lock automatically.
Old 05-12-2007, 07:15 PM
Once I get my exhaust done that would be a cool project. My power locks are hosed at the moment. I don't even have the pass door regulator installed because it's seized in the lock position.
I need to finsh my exhaust to pass safety, and that's draining my funds right now, but once that's done and I'm set for money this would be a cool project.
I got down there again and looked around for the alarm. All I could find is what I assume is the shock detection unit zip-tied to the steering column. It says "Singer doubleshock...something something" on it.
Old 05-12-2007, 07:24 PM
I love it! That is a good surprise!
Old 05-12-2007, 09:54 PM
UPnorth362's Avatar
Yea..... I can tell by the shock sensor and ignition harness, its a DEI product. You would need new lock actuators for this car anyways. No biggie though, the actuators are like $15. The window mod is like $35. Let me know when you are ready, I can give you some details on how to make it work. You could do all 4 + the moon roof. You can also make the trunk pop, and turn on neons. The possibilities are endless
Old 05-12-2007, 10:23 PM
I'll let you know when I've got the time/money to give it a shot!
I like the idea of my car doing all sorts of things without anyone in it. It would be a great show for my friends.
Old 05-13-2007, 10:41 AM
... I don't even have the pass door regulator installed because it's seized in the lock position...
Chris,
Let me know what parts you need for your passenger door, and they'll be your for the cost of shipping.
Old 05-13-2007, 11:00 AM
Originally Posted by Hocrest
Chris,
Sweet, thanks Dave! I'm living on credit till my tax return comes in, but once I have some money to move around I'll give you a shout.
Old 05-22-2007, 11:58 PM
SVXdc's Avatar
SVXdc SVXdc is offline
Radio wiring harness guru
I'm surprised the previous owner didn't tell you about this. Kinda scary — you could have squeezed the transmitter the wrong way and not realized you just started your engine...
So does the toggle switch disable the remote start?
I can tell by the shock sensor and ignition harness, its a DEI product. You would need new lock actuators for this car anyways. No biggie though, the actuators are like $15. ...
Are you talking about the SVX's factory door lock "motors" or something else? (I'd have thought the factory actuators would run way more than $15 each)
David C.
