Old 05-07-2007, 07:42 AM
JaySVX's Avatar
JaySVX JaySVX is offline
Smoke
I am getting some smoke out of my exhaust after driving the car hard. Normal driving conditions there's no smoke at all, but after pushing it hard, there's some white smoke for about 5 minutes or so, and then it's gone. What would cause this? Piston rings?
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
Old 05-07-2007, 05:00 PM
subiedo subiedo is offline
White smoke? Black is too rich on fuel, Blue, usually oil. White as a general rule from coolant which is actually steam or vapor. Head gasket failures are a frequent culprit but not being a real SVX sleuth, I'll just leave my .02 cents & hope some one has an idea about specific failures that result in your observed problem.
Old 05-07-2007, 07:16 PM
JaySVX's Avatar
ug, i hope it's not headgasket, i'm not properly equipted where i am to tackle a job like that... that's what i was thinking, coolant, but i was hoping it might be something else.
Old 05-07-2007, 08:12 PM
Romantt8 Romantt8 is offline
Check if youre loosing coolant, and check both the coolant and oil for mixing. Hopefully its just a fluke.
1992 LS-L Liquid Silver (# 7,083).
Old 05-07-2007, 08:59 PM
coolant or some other form of water... How heavy is the smoke??
Old 05-07-2007, 09:00 PM
come to think of it... mass oil burning is white(had it happen when I lost a cylinder in my ebony) Hope this is not the case
Old 05-08-2007, 03:29 AM
JaySVX's Avatar
I've checked oil and coolant multiple times, no mixing at all, and neither are every down a significant amount. It doesn't smoke at all during normal daily driving, only when i beat on it for a bit.
