Old 04-27-2007, 11:40 PM
nutshell's Avatar
nutshell nutshell is offline
Send a message via AIM to nutshell Send a message via MSN to nutshell Send a message via Yahoo to nutshell Send a message via Skype™ to nutshell
Where are the Window fuses located?
Recently my passenger door window has given up the ghost - no go no more. (at least it is closed)
Everything seems ok...the fuses in the footwell block check out ok. The switches (both of them) were working just fine and still 'feel' intact. But when I remove the door panel the black wire power circuit to the switch center is dead.
Maybe there's a relay of two that needs resetting?
Any ideas? Tests? Any more fuse locations I should look at?
Ian
"The faster I go...the older I get"
Old 04-29-2007, 11:13 AM
The wiring to control the the switches and window motors uses grounding, so I'm not sure if you should have a hot going into the switches.
Unplug the two wire connector going to the window motor, I think it has a green plug??
Check for voltage on the car side when you use the drivers door window switches. It will be positive in one direction going up and negitive in the other direction going down.
You can also use a jump box or battery from a cordless drill with some jump wires to the connector going to the motor to see if the window moves like that.
Send me a PM if you need a regulator.
